First HTPC Build Review
dvandriesen
Been doing some serious research and wanted to see what the thoughts are on this build. I am coming from a Raspberry Pi and would just like 1080p to play flawlessly. Will just be using XBMC to start no OS only streaming from XBMC addons.
Foxconn RM3-H2 BareBones (http://www.newegg.com/Product/Product.as...856119066) $90
This would include PSU/CASE/MB Intel H61
Intel Celeron G530 (http://www.newegg.com/Product/Product.as...el%20g530) $49
RAM- G.SKill 2X4GB (http://www.newegg.com/Product/Product.as...820231396) $22
Total: $160 not including shipping
I would just run XBMC off usb flash drive so no need for HDD
Or Should I go with a Intel G860 (http://www.directron.com/bx80623g860.html) $67
Would I notice much of a difference for the price? Any other help on the barebones case would be great or any other insight really just want something to start out in the HTPC scene as the Raspberry Pi is just a tease. Thanks
The celeron G530 is not a bad CPU, however, you'll want a GFX card for hardware rendering if you want to play 1080p flawlessly. i mean, sure, you might get by with some file types, but when you get to the extremely high bitrate stuff, it'll make a difference. XBMC wiki page suggests an nvidia card due to the fact that their drivers are generally better for ubuntu.
Have your link book marked from a previous post. There is no need to fork over the extra money for a i3 just used for xbmc correct.
Can you elaborate on the raspberry Pi as a tease?...I just bought one to run XBMC
