First GF104 overclock!
tweakboy
Hey yall water leaked on my 8800 soo I got EVGA 460 1GB vanilla
Using MSI Burner
voltage 1.075
Core
900Mhz
Shaders
1800
Memory
2050
Can someone help with some input if I can go any higher on any field. I heard memory can go up to 2200Mhz but I havent tried that seems way high.
Can I push the Core/Shaders any higher?
Can I push the memory passed 2050 to 2100 or soo. Thanks a lot gg and gl,
Yeah I meant to say 925mhz.
The memory should do 2200mhz no problem; mine doesn't even have a heatsink on it and it does that speed. I have a feeling it's good for 2300mhz, I just don't want to push it too far.
Wow thanks happy medium as usual and thanks sickBeast for all your help.
My temps on idle desktop go up 6c when changing voltage from stock to 1.075
Ok I maxed out the voltage to 1.087
I got her now at
920 core 1840 shaders and 2200 video ram
Thanks gb
Yeah the temps go up, but it lets you get more out of the card, and even overvolted it probably uses less juice than a 470.
6C at idle sounds like a lot though. Do you have the dynamic clocking enabled in the drivers? When you overvolt the card, it should only affect the card during gaming.
Mine is idling at 30C when it's overclocked. Under full load it gets to around 60C. It has a "cyclone" cooler on it if that makes any difference.
Thanks for your response. I have the fan @ auto 30 percent, But when I game,, I change the profile to OCed
950 core
1900 shader
2200 memory
card @ 1.087v
fan @ 100 percent
950 core
1900 shader
2200 memory
card @ 1.087v
fan @ 100 percent
100% fan for the win! Go leafblowers 🙂
I settled on 860Mhz at 1.075v for my SLI 460's, it seemed like a good balance of performance to fan speed, cards never go higher than 65c with fan speed staying below 70%.
950 core
1900 shader
2200 memory
card @ 1.087v
fan @ 100 percent
Boy oh boy, tweakster here just got one of the highest GTX460 overclocks on air on our board. That's faster than an HD5870 at this point. :thumbsup:
Thanks RussianSensation and to all for their help and input.
Ya I got the plain vanilla EVGA 460 1GB .. as oCed versions are much more and all they do is raise the voltage and OC a tiny bit, I wanted the vanilla then set voltage to max 1.087 and OC her, btw sides of my case are open. I have a 120 on the RAM and mobo heatsink.
I just played 30 minutes of UT3 and no crash or artifacts.
I have to have the fan @ 100 when gaming, and 30 in desktop. I only OC when Im ready to play a game,, with MSI burner. saved profiles.. one stock and one OC. I will let yall know if any games crash or show artifacts @ these speeds.
950
1900
2200
100 percent fan.
The memory on these cards has error correction, so the only way that you know it's clocked too high is if your performance actually decreases in benchmarks.
Wow I didnt know that. I think Ill run vantage stock and ocEd and see what scores I get.
