<< Nice. Those core-speed boosts should help quite a lot, along with the T&L engine.
But the STG5500's new core will require the increased bandwidth of DDR memory.
Interesting. >>
Naw,
I don't think so. If you look at the efficeny of the card you can see that is in the high 90s. Or look at 32 vrs 16 bit color. There is a difference but its not as wide as the traditional renders. The biggest "bottle neck" here is the number of pixels it can push out. Agreed you can not forget about memory bandwidth need. But playing around with a K2 is showing me that its much more fill rate limted than memory. Thats why the extra pixel processing power that the next gen has should help (note I am not saying DDR will not be worth it, I am saying that memory bandwidth is not the weak link yet).
