- Jul 26, 2013
- 98
- 0
- 66
I ran a i7 2600k at 4.5 GHz (1.4v) for nearly 4 years. I did have to drop it down to 4.2 recently as my system seemed to be losing stability. I purchased a 6700k with a Gigabyte Z170X-UD5. I did just fail a stress test at 4.5 GHz and 1.25v. My temps peaked around 67C (and were usually below 60C). I will probably bump it up to 1.275v next.
1) I remember load line calibration controllers were sketchy in the past. While gaming, CPU load goes up and down often, which makes me nervous with unreliable controllers. I have 3 LLC options...auto, standard, high. Auto and standard are crap. My vcore drops all the way down to 1.1Xv when set to 1.25v. The high setting seems to do pretty good, but are there burst voltage spikes occurring that are damaging the CPU due to overshoot?
2) I never used XTU in the past. Is there a reason CPU-Z and HWinfo are reporting core voltage with what I am expecting based on BIOS settings, but XTU is reporting something like 1.37v (instead of 1.25v).
3) C states were always disabled while overclocking back in the day. Is the sentiment still the same? Will the voltage actually even drop when I have a hard coded voltage (havent wanted to test this yet while working on general stability)?
4) It seems people are using voltage much higher than mine and claiming it is safe. It makes me nervous even at 1.25v on this 14nm process. What has changed since the previous generations to make people believe 1.35v+ is safe for long term use (I am hoping to get another ~4 years out of this)?
