First computer build need help
hazyeyed
11
https://pcpartpicker.com/list/yYhwyX
So I ordered this build, now i'm trying to figure out how to go about putting it together before it gets here on my old DDR2 computers I usually just slap the ram in wherever and haven't had issues but the mobo I ordered (b450) has instructions for installing the RAM in certain slots based on the CPU you bought (pinnacle ridge) however it does not say anything about 3200 MHz ram which is what I was suggested to buy and honestly it doesn't make sense to me at all how to tell which stick goes in which slot. Same thing with the GPU.
Campy
785
171
For memory refer to your motherboard manual. You won't break anything by putting RAM in the "wrong" slot. GPU goes in the PCIe slot closest to the CPU socket.
Campy
785
171
Install them in A2 and B2 slots (second and fourth slots counting from the CPU).
JackMDS
29,527
415
There is a "Faint lines" on the diagram at the memory slots that show how to pair the pairs.
:cool:
