- Jul 23, 2006
- 7
- 0
- 0
Hi this is my first post, looks a great site.
Im a bit of a noob so please go easy
This is my first build so some critique and advice would be appreciated.
Heres what ive bought so far still waiting on a couple of parts should be this week.
Antec P180 Black SPCR Advanced Super Mid Tower - No PSU (added the 2 optional 120mm antec tri cool fans ) £85
Intel Core 2 Duo E6600 S775, 2.40Ghz, 1066Mhz FSB, Conroe Core, 4M Cache Retail £240
ASUS ASB-P5B i965, S775, PCI-E (x16), DDR2 800, SATA II RAID, ATX,Supports Core 2 Duo Processors £100
256Mb XFX 7900GT Extreme,Mem 1500 MHz, GPU 520 MHz, 24 Pipes, Dual DVI-I HDTV £210
Western Digital Raptor 74GB WD740GD 10,000RPM SATA 8MB Cache - OEM £100
160 Gb Western Digital WD1600YD Caviar RE, SATA150, 7200 rpm, 16MB Cache, 8.9 ms - £50
2 x Western Digital Secure Connect Serial ATA Cable's - £15
Corsair 2GB DDR2 XMS2-5400 TwinX (2x1GB) - £147
or
Corsair 2GB DDR2 XMS2-6400C5 TwinX (2x1GB) - £127
not sure will it be worth the extra £20 ?
Sony 3.5" Floppy Disk Drive Black - OEM - £5
Antec NeoHE 430W Modular ATX2.0 PSU - £45
I bought a tube of Artic silver 3 paste is that suitable or will i be best going for the supplied one?
I will be adding a dvd dual layer burner as well still not decided.
Have i missed anything?
This machine will primarly be used for games, Battlefield 2, counter strike etc
im a bit worried that the psu could be bigger what do you think?
Any help would be appreciated
Thanks
or
Thanks
