- Dec 11, 2008
- 183
- 0
- 76
Hello Everyone, and thank you in advance for your guidance, and feedback. I will start out with some of the pre-requisite information mentioned in the Newbie Build thread:
- Use: Intense multi-tasking inclusive of torrent downloads, media-backups, streaming of stored media content, etc, however NO GAMING; Hoping to achieve streaming of True HiDef media content, uncompressed audio as well. Essentially watch, and hear the content as it was meant to be seen in the theaters.
- Price range: <$1k
- Country: Reside in the U.S.A, and most likely will either hunt around Ebay, and Newegg
- AMD fanboy
- The only current part that I may use if I decide to get rid of the Gateway (referenced below), would be the Rosewill RC-216 eSata card
- Searched the net, this site, and Cyberpower.com EXTENSIVELY!! Just when you think you've narrowed it down, then you read a few posts/reviews, and it's back to square one.
- Plan to overclock only slightly so that it can be air cooled.
- Timeframe: Here's the kicker, as I don't plan on building until possibly next Fall, possibly earlier, which should allow for prices of my tentatively selected components to come down
First I want to acknowledge that I am aware of the seemingly foolish notion that there is absolutely no future-proofed computer, and/or PC component. My hope with my first build is to extend the time-value line of my build as much as possible until technology gets to a point where I would be foolish not to upgrade, which I'm certain will happen one day.
Ok, so my goal is to stream stored media, download multiple torrents, and multi-task/browse the net from a network of two possible computers. The layout of the network in my head is to have a headless NAS box serving as the central hub from which I retrieve/add stored media to. This NAS box would then be connected to two seperate PC's.
One of the PC's will be a Gateway GM5088 Media Center PC (purchased this a couple of years ago).
The second PC will be my first build, and tentatively consists of the following components:
- Antec 900 case (already bought years ago for cooling capabilities)
- Coolermaster RealPro 1000w PSU (purchased years ago)
- 2 x WD Caviar Black 640gb HDD's in Raid 0 to house the O.S.
- Vista Home Premium 64bit
- Several WD Caviar Green WD10EADS 1TB HDD's
- Sound: Auzentech X-Fi Hometheater HD
- Video: Either the nVidia GTX260, GTX280, or GTX295
- CPU: AMD9950 BE 125W
- MOBO: ASUS M3N-HT Deluxe (not sure whether to go mem-pipe or not)
That's it for now. I realize that I missing other parts such as keyboard, display, etc. I hope to purchase an LED HDTV when they become more the standard, for now any of the current displays I have at home won't do any of the above referenced components any justice, and I'm fine with that for now.
Despite much of what I've listed being geared more towards the Gamer, I really liked the HiDef features of the MOBO, and Videocard, as well as the option with respect to the MOBO, and videocard to do Hybrid SLI.
Ok, so chastise me as you well, I am fully prepared, and eagerlly await your feedback. Some things specifically I hope to learn from you are, in addition to your critique of the listed components above:
- What memory manufacturer would you use, and what type of memory? I believe the MOBO can handle up to 8gb of RAM, however I don't know for certain if it can fully utilize/recognize 8gb of 1066 RAM. Would it be better to use 4gb 800, 4gb 1066, or 8gb 800? I've been researching Newegg/Google adnauseaum for the most reliable RAM manufacturer, and it seems like a crapshoot.
- Is my notion of incorporating a headless NAS box ideal? If so, would the components of the NAS box have to be on par with those of the Antec 900, so that a possibly inferior NAS box would be feeding media content to an "overblown" antec system. I feel as if the network would only be as good as it's weakest link, which I know then begs the question, "well, what cables, receiver, HDTV are you using?" However, solely in terms of the PC element of this "media network", should I focus more on higher-end components for the NAS box, or spread everything out evenly across the entire network, or does it even matter?
"MalVeauX" wisely stated here at Anandtech that the key to HTPC was to (paraphrasing) build a system using essentially the bare minimum of components (within reason), to achieve the desired result. One character flaw of mine is that I tend to go over board with things in life, hence the Antec 900 cooling capabilities even though I don't game, and a 1000w PSU so as to give my build plenty of power
And I'm sure a GTX295 for a non-gamer is absurd, I'm just looking at it as a SLI of the GTX260 which would give my HiDef content the best picture currently available.
That's all for now folks. Again, thank you in advance for your feedback/guidance.
Ciao
- Price range: <$1k
- AMD fanboy
Ciao
