Ok, Crysis 2 is on the horizon, and i would like to be able to play it at as high a level as possible. Keep in mind i have a good grasp on what parts I need and do what, but as for comparing model x to model y I have decided to come and ask you guys, the experts. This computer will be entirely for gaming only, as i have a MacBook pro that i do all my photo editing and browsing on.
1. What YOUR PC will be used for.
Gaming on crysis and crysis 2 as well as other visually demanding titles.
2. What YOUR budget is.
1000-1200
3. What country YOU will be buying YOUR parts from.
Canada
4. IF YOU have a brand preference.
Intel Sandy Bridge.
5. If YOU intend on using any of YOUR current parts.
Monitor, mouse, operating system.
6. IF YOU have searched and/or read similar threads.
Yes.
7. IF YOU plan on overclocking or run the system at default speeds.
I don't know much about over clocking but I would like to squeeze as much power as possible from my system. If i've left out a needed cooler or something for over clocking, be sure to chastise me.
8. What resolution YOU plan on gaming with.
1920x1080. Single screen.
9. WHEN do you plan to build it?
Within a month or so. Not in a huge rush but would like it before Crysis 2 comes out.
Parts I believe I should purchase:
Antec true power 1000w
Intel 2500k unlocked processor
Antec 300 or similar case (just want good quality and adequate space, looks are unimportant)
p67 motherboard (when they are available for purchase again)
Mushkin Enhanced Silverline Stiletto 12GB 3X4GB PC3-10666 DDR3-1333
Kingston SSDNow V100 Series 64GB 2.5IN SSD (Not sure if necessary)
Random dvd drive (dont care for blu-ray)
The part I am really not sure about is what to buy for graphics, i was looking at:
Gtx 570 or 2 lower SLi cards
Radeon 6970 or 2 lower crossfire cards.
Not trying to start an Ati vs. Nvidia war, I just want the best performance for gaming within reasonable price.
Can use any and all advice, forgive me if i've stated something ridiculous, this is also my first post and I tried to follow the format of previously posted setups.
1000-1200
Canada
Intel Sandy Bridge.
Yes.
