First Build
Orange123
How does this look?
MOBO
CPU
RAM
HDD
CASE
PSU
DVDRW
Floppy
PSU 20-24pin adaptor
I mainly just need to know is all this stuff compatible? I realize there is no video card, as hardly any gaming will be done and the onboard video directly supports OpenGL and directx 9...
The only problem is the mobo is Micro-ATX. Will this effect anything? It has a 24-pin PSU slot and my PSU is 20-pin, so thats why I'm feeling the adapter.
Let me know what you guys think...I don't need more than an 80gig HDD, 512 Ram. I really just need to know if all this stuff is compatible. I'm not looking to spend that much if any more than I already have.
Apparently all your links don't work. Why don't you specifically list out what parts you're planning on getting and also the price and where you're getting it from. Then we can give you judgement and opinions about your build and also if you're getting the best price for your build.
All of your newegg links don't work, the zipzoomfly link works fine though. It would be easier if you would just list the parts by name, rather than linking to each individual part, the way you did it with the ram, most people don't want to click that many links..
EDIT: actualy the zipzoomfly link doesn't work either, just goes to the home page and not a specific product..
Wow my bad guys...there all the links should be fixed 🙂
As for my budget, I'm looking to keep it around $500 shipped.
If there's anything else I can do to help you guys better understand what I have in mind, just ask 😉
Or better yet, can anyone find me a decent S-939 mobo with onboard video and sound for under ~$110 that is good for this setup? All my previous computers have had onboard video and for what I do on a computer that is all I need. I have searched and could not find anything decent except this
There's a 939 board made by MSI based on the ATI chipset that has integrated video.
Could you list out the parts still in writing? My connection is temporarily reduced to 56k speed from overusage and clicking on a bunch of different links is a big headache for me.
the CPU, motherboard, ram, optical drive, case, and floppy drive look fine
however i would go with Seagate Barracuda 80gb sata (good bit cheaper too)
and either this 400W PSU or 450W PSU for running stock speeds (not overclocking)
stay away from the generic PSUs at all costs
you will also want to add a couple more case fans (at least 1 in the back for exhaust
the 20-24 pin PSU adapter is NOT necessary and is a waste of money.
What I'd change for sure:
-Don't get a cheapo psu.
-Check this out first.
http://www.hardforum.com/showthread.php?t=792566
What I'd consider if I were you:
-You might want a gig. of the valueselect ram, ~$83
-I like the Chaintech vnf4ultra mobo for that price range, unless you need the msi's integrated graphics. ~$85
-You may want a venice 3000+, rather than a winchester. Only a little more $, but it can use 4 memory dimms(think future expansion) properly, unlike the winchester.
http://www2.newegg.com/Product/Product.asp?Item=N82E16819103536
You'd need a heatsink/fan for that cpu since it's oem.
-I like seagate hard drives for their warranty.
Thanks for all the reccommendations.
Sure, here is the updated system I have chosen based on what other people had said. Let me know what you guys think and should change:
MSI RS480M2-IL Micro ATX AMD Motherboard
AMD Athlon 64 3000+ Processor Socket 939 Retail
Corsair VS512MB400 512MB DDR400 PC3200 CAS2.5 Value Select Memory
Seagate Barracuda 7200.7 SATA NCQ 3.5" Serial ATA150 Hard Drive
MAXTOP Signature CSX-147K2F NO PS Gray Computer Case
XCLIO XClio 400BL 400W Power Supply
NEC Beige IDE DVD Burner
SONY MPF920 Beige Internal Floppy Drive
GENERIC 20-Pin(Male) to 24-Pin(Female) ATX Converter (if necessary)
Hope this makes it easier, I really appretiate all the help!
Orange 🙂
ok... definitely seagate HD
IMO, that case is ugly, but its your opinion that matters
dont use the 20-24 pin adapter, you can just plug the 20 pin into the 24 pin connection
(read the "do i need a 24 pin psu" thread at the top of GH)
Yeah man don't worry about the case, I understand it's not "cool" but that's all I need...I don't need any clear sided lighted case...that one is just fine.
Just to let you know it seems you may have overlooked that the 939 socket is meant for duel channel memory as you only list one stick of memory. As far as I know socket 939 can run with just one memory module but it would be just like running a socket 754.
While it is always nice to have a good power supply if you dont intend to run a high end graphics card or overclock then that power supply is probably more than you really need. Then again spending an extra $10 to $15 for peace of mind isn't a bad idea when it comes to power supplies.
I like what I see so far....I do agree with Silversierra though, a gig of ram might be a good idea. It really depends on your use of computer though, so you will know better than us how much ram you need. Ss also mentioned the venice core (Rev. E) 3000+ is a better choice for only $10 more than the winchester. I agree with this also. If your going to take any of my advice though, I'd rather you buy this Antec Sonata Piano Black case with 380w PSU $99 + tax/shipping instead. I know many people have been recommending those Xclio PSUs lately, but I really don't trust them yet, regardless of who makes what for who......especially when most people recommending them have never even used one before. The Antec 380 watt PSU comes with 24-pin ATX connector, so no need for an adapter. Plus it just looks a lot nicer, even if that's not important to you, your only spending $10-$15 more for a better looking case with a more reputable/reliable PSU. Regardless of the wattage rating, I'd bet the Antec PSU is just as good, if not better than, the XClio's. Good luck with your build....let us know how it goes.
I thought I read somewhere that stated S-754 was starting to become less popular with no options for upgrade in the future. I figured to go S-939 since it's relatively the same price and it features a 1000 FSD rather than 800.
I think you should stick with 939. You can always add another 512 down the line and get dual channel.
Unless it's out of stock, I think the XClio 450watt is only a few bucks more than the 400watt model. It's already a 24pin PSU, so you wont need the adapter.
