- Sep 26, 2004
- 93
- 0
- 0
Case: Cooler Master Wave Master (Black) or Silverstone SST-TJ05 (cant decide)
CPU:AMD Athlon 64 3500+
MOBO:MSI "K8N Neo2 Platinum" Socket 939
RAM: Corsair Value Select 184 Pin 1 GB (2X512MB) DDR
DVD: Sony Double Layer DVD Recorder DRU700A
HD: 2XFrom my old computer
PSU: Antec 480W "TRUE480BLUE"
Video Card: TBD (need to find good deal)
So what do you guys think? Machine will basically be used for gaming plus a little of everything else. So for a first time builder, does someone have a good "Make sure you..." or " Whatever you do don't...." list? I would appreciate all the advice you guys can stand to give.
By the way, will I need to add extra fans or will the ones with the case and processor be enough?
Thanks in advance! - CJR
