First Build
RadioHead84
2,166
I started my first build today. And i ...cut myself jeez. I was trying to push a CD rom drive into position and it slipped and flew out the other side. in the process i managed to cut myself. I am very discouraged now and hope my comptuer will be ok in the end. I have the Mobo and Cpu install. All i have left is the DVD-R, CD drive, Memory and sound card. I did ruin that CD-R tho..that sucks :(
ah man.
tfinch2
22,114
ohhhh noessss blood on the hardware!!!!11111!!!!oneoneone
don't worry it will turn out fine ;]
mechBgon
Oct 31, 1999
30,699
Ooo, a saucy computer that fights back :D You need an umpire...?
AyashiKaibutsu
9,306
4
My case bit me one time... I was taking out the original I/O shield man that was a bitch... it pinched my finger to the point where it cut me and intially a lot of blood appeared but it subsided really fast. Subsiquint I/O shield changes haven't been nearly as hard meaning Antech put it on too tight grrr >.<
chipy
1,469
yeah, i cut myself a while back on an old antec case... don't worry about it.
take it nice and easy and everything will come together at the end.
chipy
Confusednewbie1552
1,047
I got my pinky finger stuck in between the removable mobo tray and the case a couple hour ago. Thre was blood, but I quickly cleaned it off the case, and my finger =D
VirtualLarry
56,571
10,207
Yeah, everybody bleeds the first time... you wise up after your first build though. Unless you like to bleed, you start buying better-quality cases that don't have those !#@%!#@% sharp edges on them.
What's really scary, is buying a case, and finding out that the bottom of it has been pre-bled-on during assembly. :( It's one thing to be exposed to your own blood, it's quite another to be exposed to unknown blood. There's nothing that says "sweat-shop labor" more than bloody cases, I'll tell you that.
Bovinicus
3,145
Yeah, unless you're cheap like me and keep the same cheapo case for several years. As well, I do work on plenty of people's systems as freelance work; nothing like a pre-built turd to give you some fresh wounds.
Gurck
Banned
Mar 16, 2004
12,963
Same here, first case was ubercheap (Ill save teh munney!!1!1) and sliced &amp; diced me pretty good. PSU died as an added bonus. Current case is an Antec and I :heart: it
Mem
21,476
13
Heh. I think we've all cut ourselves.
I cut myself last year while changing a PC between cases,I didn`t know until I looked at my fingers lol,I was too busy moving hardware around to notice ;).
RadioHead84 good luck with your first build :).
Gurck
Banned
Mar 16, 2004
12,963
Originally posted by: GregMal
Isn't sheading blood a rite of passage in building a PC?
Greg
Not if you buy a quality case, but most first-timers won't listen ("it's just a case, why spend more on it?") and so it happens ;) I was no different.
CeilingHoles
171
I got 2 cuts my first time building, but i never noticed it until long after.. I was using a quality case tho (Antec Sonata)
Gurck
Banned
Mar 16, 2004
12,963
I dunno what you did then :p People don't get much more clumsy or hamhanded than me, but I found nothing but rounded edges in my case
Kishan
2,580
this man preaches the truth! can i get a amen?!
RadioHead84
2,166
Ah there is a bandage on my hand..BUT i am typing this from a new computer!
I have everything installed..I think ineed to update my drivers again but ah well..
is 89F ok for a computer temp?
The computer!:
3500AMD64
MSI NEO2 Plat
Corsair pc3200 XMS XLL
6800GT
480 Antec True
Dvd Dual NEC
sound good?
JonathanYoung
379
I cut myself trying to pry off a drive bay cover from the inside. It was super deep and the blood gushed out nonstop and dripped all over the floor... scared my girlfriend, since I was installing a CDRW for her!
