- Aug 20, 2012
- 4
- 0
- 0
I am planning on building my first system that will be used for Autocad and Solidworks. I am new to this so I would like to know what you recommend given my budget and usage.
Thanks.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Autocad, Solidworks, Matlab, and gaming (minimum)
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$2000 - $2200 USD
3. What country YOU will be buying YOUR parts from.
USA - California
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
None.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
None.
7. IF YOU plan on overclocking or run the system at default speeds.
Overclocking in the future.
8. What resolution will you be using?
I need monitors. I would like a dual monitor setup.
9. WHEN do you plan to build it?
Within 2 weeks.
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
I'll get a copy of Windows through my school.
Thanks.
$2000 - $2200 USD
USA - California
None.
None.
Within 2 weeks.
