First build ready to order
bluey
Finally now that the 6800gt has come out I'm ready to order my parts for my first home built computer. Will order this probably sunday or monday, any last comments? Thanks.
COOLER MASTER CENTURION 2 Black ALUMINUM MID-TOWER CASE, Model "CAC-T02" -RETAIL
2-Vantec "Stealth" 80mm Case fan, Model "SF8025L"
MSI "K8T Neo-FIS2R" K8T800 Chipset Motherboard for AMD Socket 754 CPU -RETAIL
Antec 550W Power Supply, Model "TRUE550" -RETAIL
AMD Athlon 64 3200+, 1MB L2 Cache, The Only 64-bit Windows Compatible Processor - Retail
2-Kingmax 184 Pin 512MB DDR PC-3200 - OEM
Mitsumi USB Digital Card Reader/Writer W/FD (Black)INTERNAL, Model FA404A/404M
Seagate 120GB 7200RPM SATA Hard Drive, Model ST3120026AS, OEM
Lite-On 16X DVD-ROM Drive, Model XJ-HD166S, OEM
Creative Labs Sound Blaster Audigy2 ZS PCI Sound Card, Model "SB0350" -RETAIL
BFG 6800gt
Lite-On Black 8X DVD+/-RW Drive, Model SOHW-812S, OEM
The only last question is the DVD burner. In the past two months has anything come about (dual layer) that would be better? I could just wait a month or two on the burner if they are close, I dont know I havent really been paying too much attention lately due to working so much.
Thanks guys
well, there are several dual layer dvd burners. nec makes very good and cheap ones and they go 8x. i think a majority of the people here would vote for nec for their quality and price.
I agree with the above poster, a 550W power supply is complete overkill for your computer. Save $40 and get the Antec True 430.
Get the newcastle, 2.2ghz/512k L2 cache version of the 3200+ instead, it is faster and almost $40 cheaper.
If you want quiet case fans, get Panaflo's, they are quieter than Vantec Stealths. You can get them here.
Nice system you got there, just one question. Where are you ordering the BFG 6800 GT from? They don't seem to be in stock in too many places.
Looks fine for the most part. If you plan on overclocking, however, it's imperative that you switch the motherboard to something with an nForce3 250 or K8T800 Pro chipset - MSI K8N Neo Platinum, Epox 8KDA3(+/J), Asus K8N-E Deluxe, Abit KV8 Pro. If you're not, then switch the 3200+ to a 2.2GHz 512K version, as it's faster at stock speeds.
Also, your power supply looks like it'd be way overkill, but if you're just being paranoid about it that's fine I suppose.
Keep the power supply! and you'll be happy for many years.
i got same replies a few years back when my 256MB system memory and my 250W psu was overkill. huh.
Ok thanks for the suggestions. I got the newcastle version of the 3200+, but I am not planning on OCin so I will stay with the board. Oh and this may sound dumb but will I need the 3 pin connector for the panaflo fans?
