I'm jumping in to my first build. I intend to use the rig primarily for imaging. Any suggestions, dumb choices...
AMD Opteron Model 146, 1MB L2 Cache 64-bit Processor - Retail
ASUS nForce3 Pro150 Chipset Motherboard for AMD Socket 940 CPU, Model "SK8N" -RETAIL
SAPPHIRE ATI RADEON 9800PRO Video Card, 256MB DDRII, 256-bit, DVI/TV-Out, 8X AGP -OEM
Corsair XMS Extreme Memory Speed Series, Low Latency (Twin Pack) 184 Pin 1GB(512MBx2) DDR PC-2700 with Platinum Silver Heat Spreader - Retail
Western Digital 160GB 7200RPM SATA Hard Drive, Model WD1600JD, OEM Drive Only
Allied TRUE 450W Power Supply AL-B450EATX w/ Two Fans ***AMD APPROVED good to 2200+ *** UL, CSA, FCC
Approved
Thanks, eh!
Approved
Thanks, eh!
