Question First build : is it ok ?
Marshally
Hi guys, as the title states, this is the fisrt time i try to build a pc.
I just want something that can run latest games properly with min 60 fps without coughing.
I own everthing except the case and its components.
I've informed myself about all components but i dont want to make a mistake buying something worthless or something that could have been better and cheaper.
So what do you think about this compo pls ?
- MSI GeForce RTX 3060 VENTUS 2X OC (LHR) Carte graphique PCI-Express - Refroidissement semi-passif (mode 0 dB) - Avec backplate - Compatible VR
- Intel Core i7-12700KF (3.6 GHz) Processeur Socket 1700 - 12 coeurs - Cache 25 Mo - Alder Lake - Ventirad non inclus
- GIGABYTE Z690M DS3H DDR4 Carte mre mATX - Socket 1700 - Chipset Intel Z690 - USB 3.1 Type C - SATA 6 Gb/s - M.2
- Noctua NH-U12S chromax.black (Compatible Socket LGA 1700)Ventirad Tour - PWM - Socket AMD AM5 / AM4 / AM3(+) / AM2(+) / FM2(+) / FM1 et Intel 2066 / 2011(-V3) / 115x / 1200 / 1700-
- Enermax MarbleBron RGB Blanc - 850W
- DDR4 Corsair Vengeance RGB RS Noir - 16 Go 3200 MHz - CAS 16 Mmoire DDR4 optimise Intel et AMD - PC-25600 - LED RGB
- Zalman R2 - Blanc Boitier PC Moyen Tour - E-ATX / ATX / mATX / Mini-ITX - USB 3.0 - Avec fentre (pleine taille)
- Samsung 980 500 Go SSD M.2 - PCI-Express 3.0 NVMe - Contrleur Samsung Pablo - Lecture max : 3100 Mo/s - Ecriture max : 2600 Mo/s - Mmoire TLC 3D
- Seagate BarraCuda 2 To Disque dur 3.5" - 7200 tpm - 256 Mo - SATA III - Bulk
Tech Junky
3,825
1,343
Much easier to parse if you put it into PCPartPicker.com and there may even be a fr version.
