first build - is everything ok??
jrm5084
Hello, i'm getting ready to order all the parts from newegg, i just wanted to make sure that everything i'm about to order is compliant wiht eachother or if there are any other problems/suggestions with the hardware i ordered.
Cpu: Amd Athlon 3800+ venice core - retail ($372)
Mobo: Asus A8V deluxe ($115)
HDD: Western Digital Caviar SE WD1600JD 160GB 7200 RPM Serial ATA150 ($82)
RAM: Corsair ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System ($80)
DVD/CD: NEC ND-3520A BK ($46)
Case: ASPIRE X-Dreamer II ATXB4KLW-BK Black Steel ATX Mid Tower Computer Case 420W Power Supply ($55)
These are all the parts i'm ordering for my comp, i already own a monitor and video card. Are there any parts that are conflicting with eachother, or any parts that i'm missing or gonna need in order to build the pc. Also, i already have the mouse, speakers, keyboard, etc.
If you have some extra cash, try to invest in Asus A8N-SLI deluxe and buy another video card later.
