Hello! I have not been in the PC building game for a while, but I have spent several hours attempting to catch up. I am somewhat familiar with what is out there, and specs for most things, but I lack the benefit of actual hands on experience with any current hardware.
My old PC is an opteron 170 still @ 2600 with a scythe ninja, good RAM, a Radeon 1950xtx, Dual 74gb Raptors in RAID 0, Enermax 750ish watt PSU, Antec p180, etc. Rig has held up like a champ but its time has come. Not much reusable either.
Here is my current list. My primary issue is with motherboard selection. I wish to avoid spending a ton on one, but I want a quality board that will OC well and last.
I am one of the worst here, as I spend a lot of time searching for the best combo of price, performance, and quality. Just like with cars, you are supposed to pick 2 😉
CPU: Haswell i5-4670k
Pretty set on this, but I appreciate input.
http://www.newegg.com/Product/ComboD...=Combo.1455442
Motherboard(s):
Asus z87-A or better
Gigabite z87x-d3h
Asrock pro3 or better
Very open to suggestions here. Features are not as important, although the ability to access PC from remote smart devices is nice. Will eventually get an audio add on card.
RAM: g-skill Ripjaws 2x4gb PC 2133 cas 9.
Fastest, cheapest quality memory I could find.
http://www.newegg.com/Product/Produc...82E16820231689
GPU: Asus HD-7970
This is, from what I can tell, the best bang for the buck card ATM. The 3 slot config concerns me, as does the lack of an HDMI port. If I were to eventually go SLI or Crossfire, would there be a better option that is still a solid card by itself?
I plan on playing FPS, RTS, and a good variety of games including ARMA 3.
Therefore I want a card that does well now, and will not break the bank to double up down the road.
http://www.newegg.com/Product/Produc...82E16814121560
Boot: Sansung 840 pro 256 gb MLC
Open to the possibility of the 128, but I want fast. See my previous system 🙂
http://www.newegg.com/Product/Produc...82E16820147193
Storage: Looking at WD 2TB drives as I have a lot of torrents and videos stored on an external. I want stability and reliability, so the reds came up. Could use some suggestions here.
http://www.newegg.com/Product/Produc...82E16822236343
PSU: Antec NEOECO 620w.
I recognize the need for a solid PSU, but I dont want to break the bank here either.
http://www.newegg.com/Product/Produc...82E16817371031
Monitor: Asus VG248QE.
http://www.newegg.com/Product/Produc...82E16824236313
Would like to slide in one of my 19" NEC until I can get a second 🙂
1. What YOUR PC will be used for.
In order: Gaming, video storage and viewing, minor photo editing, general productivity, and misc.
2. What YOUR budget is.
I would like to stay around $1500, complete with monitor, but I am flexible where quality and future proofing is concerned
3. What country YOU will be buying YOUR parts from. USA
4. IF you're buying parts OUTSIDE the US... N/A
5. IF YOU have a brand preference.
Not really.
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are. Currently have all peripherals. I dont think much else is usable
7. IF YOU plan on overclocking or run the system at default speeds. Default speeds at first, but I want hardware that will support OC.
8. What resolution, not monitor size, will you be using? looking into widescreen with the Asus 24" that is getting rave reviews. Also have occassional desire to run HDMI to my Samsung 51". Currently running dual NEC 19" at 1280x1024
9. WHEN do you plan to build it? soon
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software? Probably Win 7[/QUOTE]
Motherboard(s):
Gigabite z87x-d3h
GPU: Asus HD-7970
Not really.
