Hi Anandtech,
Got a surprise holiday bonus, and after being a gamer for 20 years (I'm 25) and always buying pre-built/friend built/barebones + upgrade systems, I'm finally ready to blow some good earned cash on a gaming machine that makes me giggle. I've never played anything on the highest settings until like 6-7 years after the game comes out. This is going to be silly. List of games:
HoN/WoW/Civ4,5/Borderlands/Skyrim/Battlefield/MMO's/etc.
All RPGs/Strategy, and some shooters, usually prefer multiplayer shooters.
My main questions are: 1. Should I shift my build if it's only 1920x1200 versus the 2540x1400 or whatever that is? 2. Overclocking? 3. If I took off $200 from this build it would seriously hurt performance, right? 4. SSD's? I think I get why they rock but I've never used one -- just put your operating system on it right?
Thanks everyone!
LITE-ON DVD Burner $17.99
NZXT Source 220 CA-SO220-01 $49.99
Seagate Barracuda ST1000DM003 1TB 7200 RPM $79.99
SAMSUNG S24A450BW-1 Black 24 $289.99
SAPPHIRE 100351SR Radeon HD 7970 3GB $379.99
XFX Core Edition PRO750W (P1-750S-NLB9) $89.99
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 $35.99
ASRock Z77 Extreme3 LGA 1155 Intel Z77 HDMI SATA $124.99
Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) $219.99
Crucial M4 CT128M4SSD2 2.5" 128GB SATA III $109.99
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1,400 all-in
3. What country YOU will be buying YOUR parts from.
US
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Best value, that's it
7. IF YOU plan on overclocking or run the system at default speeds.
Default speeds but open to overclocking -- I have never done it before
8. What resolution, not monitor size, will you be using?
1920x1200
9. WHEN do you plan to build it?
Note that it is usually not cost or time effective to choose your build more than a month before you actually plan to be using it.
Soon/Now
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Naw.
Thanks everyone!
Gaming.
$1,400 all-in
US
1920x1200
Soon/Now
Naw.
