First Build - Comments (Ordering Today)
EXEEMLITE
508
Well there are several schools of thought on your mixing a p965 with a 6600, Mostly from what I gather your best bet is to go with a 975 board. 965 is best for 6400/6300. Secondly, I would look for a better cooler, tuniq, 120, or even a zalman 9500. These things are very strange when it comes to cooling them. If you are going to oc, and you are by the purchases. I would definately upgrade the cooler to the best you can get/afford. Other than those two things nice build. I am sure you will be happy with your purchase. Ofcourse,if money is there you may REALLY want to take a look at the 680i board, 1 word for those so far NICE.
Mr Fox
876
You Might want to re-think your PSU and Memory.
The OCZ PSU has Quite a bit of Ripple....
http://www.jonnyguru.com/review_details.php?id=35
That Memory is Elpida Chips.... and not very able to run in different modes.
Any of the below listed memory is Micron D9 based.
DDR2 800 (PC2 6400)
BUFFALO Firestix 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory ? Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820150054
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820145168
Crucial Technology Ballistix 2GB kit (2 x 1GB) DDR2-800 PC2-6400 Memory ? Retail
http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=80061-9
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820231065
Patriot Extreme Performance 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820220174
SUPER TALENT 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820609026
http://www.ewiz.com/detail.php?name=T800UX2GC4
Team Group - Team Xtreem 2 Gb Kit DDR2 (2 x 1Gb) 240-Pin DDR2-800 (PC2 6400)
http://www.tankguys.biz/ddr2-44410-800m...sCsid=f4298906ac5457e7b0b44172b58de39d
WINTEC AMPX 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory ? Retail
http://www.newegg.com/Product/Product.asp?Item=N82E16820161063
ProSlayer
52
All the 975X motherboards on newegg have 2x PCI-16 slots, which I don't need. The brand-name Asus ones are over $200, which I can't afford. The AC Pro are the best for the price, so that's why I got them. I don't plan on overclocking too much, so it really isn't worth it to me to get an expensive CPU cooler.
ProSlayer
52
Mr Fox - I heard DS3 has problems iwth the Micron D9 chips, so that is why I didn't choose them. Also, can you recommend any better PSU's, I will probably upgrade to a 8800GTX video card in one or two years, so I need a PSU capable for handling that.
n7
21,281
4
Check thru the PSUs jonnyguru.com has reviewed.
Here's one of many good ones: http://www.newegg.com/Product/Product.asp?Item=N82E16817139001
As for RAM, do not get that Corsair unless you are not OCing, & even still, i wouldn't suggest it.
There is far better RAM for the money.
Get something from the list Mr Fox mentions, as yes, that is far more scaleable RAM.
Your HSF is not terribly good.
Better than stock, but not great.
Tuniq Tower, Scythe Ninja/Infinity, Thermaltake Big Typhoon, Zalman 9500/9700 - there are a few better ones.
Operandi
Two things.
I think there are better choices other then OCZ. You certainly don't need this much power but the 550 watt Seasonic Enegy Plus S12 is better unit of roughly equivalent power.
If you are buying XP Home for the upgrade to Vista you should know that the "Home" version entitles you to only the lowest end version of Vista with many features removed, including Glass.
n7
21,281
4
Yeah 7900 GS OCs very well, & it's actually very comparable to the X1950 Pro even at stock, so i'd stick with it.
But either card is good.
