I'm looking to build my first system and think I've put together a full list of the components I want. I'm striving to build a comp that will be able to play games, deal with high res imagery in Adobe software, etc. at high resolution (my monitor is 1920x1200 native).
I'm working with budget of about $2000 for what goes inside the case. I'm not sure if some of the components are overkill, if I'm missing something important, etc.
Here's what I'm planning to get;
Case Lian Li PC-7B plus II
(EDITED as per posted recommendation)
MB ASUS P5W DH Deluxe (with new BIOS)
CPU Core 2 Duo E6700, when available
GPU Gigabyte GV-RX19X512VB-RH Radeon X1900XTX - chose this over Nvidia 7950GTX since I could use it later as a physics board
PSU OCZ GameXStream OCZ600GXSSLI ATX12V 600W or FSP Group (Fortron Source) FX600-GLN ATX12V/ EPS12V 600W All-In-One Power Supply , depending on price at time of purchase
(EDITED as per recommendations in thread - THX!)
RAM OCZ Gold 2 GB (2x1GB) PC28000 (5-6-6-15)
HDD Seagate Barracuda 7200.10 320GB SATA
DVD Pioneer 16X DVD±R DVD Burner With 5X DVD-RAM Read Black ATAPI Model DVR-111D
ANY advice would be greatly appreciated!
