Not at allIs the N14 significantly louder?
Both will achieve low enough temps at 4.5 or so to not impact longevity in any practical sense of the word. Plus the idea of extended longevity isn't really compatible with a 5GHz overclock that needs 1.4-1.5V core voltage. And temps with D14 at 5ghz are probably easily higher than with with C12P at 4.5, due to that extra voltage. D14 is really worth paying for only to get super high OC's. C12P does what a cooler needs to do at low noise and temps for less $I know you already explained that its not needed but $15 isn't big money and if the temps on the cpu are lower I'm sure it will reduce longevity and make it possible to overclock to 5Ghz in the future.
I would guess not, but not 100% sure.Can the ASrock Extreme3 handle 5Ghz?
Well, if you get a DOA item or it if dies within its warranty period, you can usually deal directly with the shop you bought it from. If you bought the item overseas via ebay, doing returns is obviously a bit problematic, and you have to manage RMA directly with the manufacturer instead of letting your place of purchase do that for you (ebay sellers aren't official retail partners of the manufacturer).Yeah I buy 99% of my stuff from ebay. Is it different with computer hardware?
No, 6970 is only about 10% faster. And the MSI 6950 should unlock into a 6970 with a BIOS flash. If it doesn't you can still easily OC it manually to about the same performanceSo this won't perform significantly better then the MSI 6950 to pay another $160 for?
http://www.koitech.com.au/products/g...b-overclocked/
Yes, the difference is easily noticeable to me. But I don't consider the actual output quality a major advantage - the equalizer and Dolby headphone functions have a lot more impact on how things sound, I absolutely love being able to customize the sound profile of whatever I'm listening to (and my headphones need a bit of extra bass and lower midtones, to my ear). And Dolby Headphone just makes everything sound more natural, but some people complain it makes it sound like you're in an auditorium. I don't get that effect with my Sennheiser PC350Is there a noticeable difference to the stock motherboard sound card?
In that review, it's slower in some tests, faster in others, and the difference throughout is only one or two fps here or there. Nothing you should consider when making a purchase choice. The MSI 6950 will be quieter and cooler.
Looks great :thumbsup:. The only thing I should still mention is that 1/4 of the price, or $430, is just for the case and PSU. It's true though that the selection of PSUs at koitech isn't great and the case is a personal choice, and that both will last a long time. Still, I'd just save $100 on the case (Corsair 400R) and perhaps also $40 on the PSU (TX750 V2).This is the updated component list
Looks great . The only thing I should still mention is that 1/4 of the price, or $430, is just for the case and PSU.
The graphics card BIOS is essentially the firmware for the GPU, and it can be modded. A 6970 BIOS can be written into a 6950 2GB because they're structurally the same GPU, and have the same amount of VRAM. The 6950 is only lower clocked and has some of its shaders locked. It doesn't always work, and in such an event the card needs to be flashed back into its original BIOS. I've read many reports of it working for the MSI 6950 Twin Frozr II. See http://hardforum.com/showthread.php?t=1622205 for instructions.What is BIOS flash? Just adjustments in the Bios?
Not annoying at allSorry about all the annoying questions again haha but your always have the perfect answers.
It's by no means essential, it will increase the 6950's performance by a small bit. Overclocking the GPU to 6970 clock frequency (800mhz to 880mhz) has more impact.
As far as I know the 6970 BIOS will have the unlocked shaders, the 880mhz clock, and possibly a change in voltage as well, not sure. So by flashing the card you also OC it. Though I suppose it'd be possible to edit the BIOS before flashing, so that it unlocks the shaders but keeps the clock at 800mhz, and then overclock it manually.So when you change the 6950 to 6970 via unlocking the shaders does it increase the clock frequency too?
This should be a good overview http://en.wikipedia.org/wiki/ShaderI just need to read about how GPU's work to understand it more as I don't fully understand what shaders are.
The original reference models included a BIOS switch on the card just for convenience to users who like to mod their card by BIOS flashing. Almost every reference model was unlockable at first, but later ones were not, I think. Nothing stops the card manufacturers like MSI from providing unlockable non-reference versions, howeverWill AMD catch onto this soon? or they don't mind?
Twin Frozr III Power Edition is a fantastic card, perhaps a bit cooler than Twin Frozr II, and more tweakable and overclockable. It'll overclock well beyong 6970 stock speeds, you could expect something like 1GHz core clock. It should also unlock the shaders. Personally I think it's worth paying maybe ~10% extra over the TWII (cos it can be about that much faster when properly OC'd).Is it worth getting the Twin Frozr III over the Twin Frozr II?
Why not just pay another $15 for the N14 instead of the C12P and have the best cooling? Is the N14 significantly louder? I know you already explained that its not needed but $15 isn't big money and if the temps on the cpu are lower I'm sure it will reduce longevity and make it possible to overclock to 5Ghz in the future. Can the ASrock Extreme3 handle 5Ghz?
You mean D14? It's also enormous and a pain in the ass to work around.
Another thing to understand is that there is a significant luck factor in achieving a high overclock without insane voltage (less that 1.4V I think). A big system builder posted some stats where 95% of i5 2500K's will make it to 4.0GHz, 50% to 4.5GHz, but only 5% will make it to 5.0GHz. This is completely depending on the chip itself and independent of the cooling and motherboard that you have.
Or you could just get normal RAM that doesn't have tall heatspeaders.![]()
You can get a cheaper case if you want.
*cough* HAF 912 *cough*
0dervish0 said:Lehtv how do I overclock with the MSI 6950 2GB if it doesn't have dual bios switch? Do I just hope it works and if not have to get another graphics card from somewhere? The motherboard has a Clear CMOS Switch, will that reset the bios?
I don't think it's worth it. You'll only ever need SATA 6gb/s for SSDs. USB3.0 devices can be plugged in the back or you can use USB2.0 on the front if you're not moving a lot of data. And Extreme3 already has x8/x8 pci-e capability. Extreme4 only adds another x4 lane which is only needed if you have a dual-GPU setup and a device that won't run in an x1 slot. Most audio cards for example can run in an x1 slot, some run in a regular PCI slot.Considering getting the Extreme4 which will allow me to use the cases USB 3.0 (internal USB3 headers), two more SATA3 connects (for future drives) and one more PCI-E 2.0. Is it worth paying another AUD$45? Seems like everyone gets the extreme4 instead of the 3.
No need to pull it out, just plug the cable to the motherboard instead of the GPUCould I just pull out the discrete graphics card and use the intel integrated graphics and then change the settings on the discrete card?
Another option is to try and find a dual-BIOS Sapphire 6950 Dirt3 Edition. I think that one has the 6970 BIOS preloaded in the switch. Didn't recommend it earlier as it isn't sold in msy or koitech.
um.. not to be mean, but we are every much up to date on the latest hardware specs and rumors.. xD
