After a long run my i5 760 from 8.5 years ago seems to be dying. This is my main desktop at home and I'm sort of happy on some level to upgrade my system. The reason is sort of stupid, but I want to upgrade from Windows 7 to Windows 10 so I can have bluetooth support for my XBoxOne controllers when I play Rocket League (Microsoft only supports Windows 10+) and that hasn't been a good enough excuse in the past to shell out money. Plus, with how computer hardware finally sort-of plateaued around a decade ago, I've gotten WAY more life out of this system than anything in the past. Just a few upgrades here and there - more hard drives, more memory, a new RX 480 GPU just before the bitcoin price surge ~2.5 years ago.
On to the questions -
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
This is my main home desktop. I use it for a lot of multi-tasking: browsing, streaming, my main music hub (playing mp3s, etc.), playing ridiculous amounts of Rocket League. I'm sure I'll be checking out Red Dead Redemption 2 if it ever comes out for PC (I've played Witcher 3, Fallout games, etc., etc. in the past). General office use - Word, Excel - whatever.
I'll say I do like to multitask a bit. I might be watching/streaming something while playing Rocket League on the other monitor, as an example or listening to music while playing a more resource intense game. My old i5 760 has always handled this, no problem.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
I can spend whatever if it's worth it. Right now, as you can see from below, it looks like I'm coming in around $600 - $700 which is fine.
3. What country YOU will be buying YOUR parts from.
US. I have a Microcenter near by for their hot CPU deals.
5. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Not really. If I were getting a new GPU (I don't think I am) I'd probably lean towards nVidia since I always seem to have soe bugs or issues with ATI. I like quality and quiet components (like Seasonic PSUs), but my fanboydom is out of date - quality changes over time and I've been out of the scene (I remember we all swore by Seagate HDDs - quiet, dependable, etc. - and then all of a sudden the quality dropped off and they started dying).
6. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
See below, current parts denoted in blue.
7. IF YOU plan on overclocking or run the system at default speeds.
Probably default unless overclocking is just so easy to do these days that everyone does it, with an expectations of noticeable performance boost without concerns of reduced life.
8. What resolution, not monitor size, will you be using?
Gaming in 2k - 2560x1440
9. WHEN do you plan to build it?
ASAP. My computer is down so I want to make decisions quickly.
Here is what I'm thinking. I see you all are using this part picker tools so maybe I'll try to put my stuff in there later, but for now:
Thanks - this site and the community always been amazing and helped me put together some awesome systems at some awesome prices! You guys rock.
- CPU $240 core i5 9600k
I'm good with my current i5 and tempted by the gaming single-processor advantage of the new i5. The cheaper price of the AMD Ryzen 7 2700, plus the overall multi-core processing advantage is tempting but I don't know if I need it. Right now I'll play Rocket League while streaming on Netflix on my old system which works just fine. Maybe I could see playing music while playing Read Dead Redemption 2, whenever it comes out for PC, but I think the either CPU would be fine with either. - CPU Cooling $? TBD. I haven't looked into this yet, but a quieter (generally larger) fan is important to me.
- Motherboard $100? I need to spend more time looking at this.
- 6 Sata would probably be good. Maybe I could survive w/ less
- I think I want that SSD M support, but that seems pretty standard
- I think one PCIe GPU slot would be fine
- 3 - 4 PCIe peripherals for future expansion is plenty
- RAM ~$100 or less, TBD. 16GB (4x4 or maybe 8x2)
- SSD - $100+ 1TB SSD, maybe that M form factor? I need to research this - it will be my first home SSD (my work laptops have had them for the past ~decade)
- HDD - Various other Hard Drives from my old system.
- CD/DVD - From my old System
- Windows 10 Pro $110 - Wireless bluetooth XBoxOne support for Rocket League is very important so I need Windows 10
- PSU - Can I stick with my current PSU or is it a bad idea to reuse it after 8+ years of heavy use? This is all assuming I don't discover it's part of why my old system died. Also, I will need to review and make sure it's good enough for the power requirements of my existing system once everything shakes out. SeaSonic S12II 520 Bronze 520W
- Case - Reuse my current case unless I find something won't fit in it (unlikely) - Thermaltake Armor A60
- GPU - From what I can tell what I've got is plenty good performance compared to newer options out there - I would either need to spend a moderate amount (like $250+) for modest performance improvements at best or spend a crazy amount - MSI Radeon RX 480 4GB
- Monitor - Dell U2515H (2560x1440). No special GPU sync support features.
- Monitor - some run-of-the-mill 1920x1020. No special GPU sync support features.
