first AMD Radeon Pro Duo ReviewWorld’s Fastest Graphics
csbin
908
614
http://www.expreview.com/46810-all.html
Radeon Pro Duo vs.GTX 980 Ti
1080p
4k
Radeon Pro Duo vs.Fury X
1080p
4k
10,457
10
The only major surprise here is the power usage.
They are really hammering down on the bios, to prevent excessive power draw.
Basically this is the Nano variant of CF and that kind of performance with that power usage, is insane perf/w.
swilli89
1,558
1,181
Regardless of everything else, truly awesome performance in a single card package! If you have the cash, this builds the ultimate HTPC.
Feb 19, 2009
10,457
10
I don't know how this thing is going to sell besides people needing a one slot or mITX build...
With Polaris coming soon at mainstream affordable prices, grab 2x Polaris 10 and you have this thing beat at a fraction of the $.
It makes more sense as a Firepro, 16Tflops FP32 performance is extremely good in a single slot.
.vodka
1,203
1,538
It's quite good considering you've got two Fijis power capped, total system power of +10w over the 980Ti setup, and 60% better performance. Both can be overclocked, though.
If you've got workloads that make use of xfire or both GPUs at once and have to make the most out of a single PCIe slot, it's an interesting proposal. Nothing that you couldn't get with two Nanos and power capping/undervolting them.
Elixer
10,371
762
It is showing that the throttled Fijis are dominating in 4K.
If one has the correct cooling, and there is a way to not throttle these things, and you don't care about power draw... this could be one of the best mining cards ever released.
Feb 19, 2009
10,457
10
It's better than CF Nano, due to the air cooler on that thing, in CF will throttle clocks even more.
This seems to hold a ~1ghz clock speed at that power profile, is very impressive for that reason, but the price makes it DOA unfortunately it's simply too late with next-gen coming in 1-2 months.
Adored
256
Yeah you'd never actually buy one of these but as a tech piece it's quite something.
Abwx
11,873
4,857
But the 980ti will overclock 30% negating most of that advantage..
30% overclock is 69% more power consumed, you can get lower than this but at the expense of stability.
And btw, what happened to perf/Watt, it does not count anymore.?..
nerp
9,865
105
Not to mention heat. The 980Ti is pushing 80C in these tests. OC that? Bleh.
Triloby
587
275
Wait a minute. I thought the Pro Duo was a pair of dual Fiji chips on one board. A dual GPU card in other words.
How would it actually perform against two Fury X's or two 980 Ti's? Especially against two overclocked 980 Ti's? I'm far more curious about that.
That said, the low power consumption is pretty amazing.
Mopetar
8,478
7,711
If this had been out 6 months ago, maybe, but as close as we are to seeing Polaris and Pascal launch, I can't imagine anyone, even someone with money to burn, buying this.
3DVagabond
11,951
204
Yeah, this likely is TDP capped like Nano. Move the slider to +50% and gain ~15% performance.
I'm most curious to see what other niggling thing they find to crap on this card about. Noisy pump, coil whine, _____? What will it be this time, I wonder?
3DVagabond
11,951
204
ding..ding..ding..ding! We have a winner! Heat and noise won't matter either. ;)
3DVagabond
11,951
204
They are comparing it to the fastest cards currently available.
If all of a sudden you are expecting the dual GPU beast to be better value than the 2x single cards are, you are in the wrong era. There's a premium for the top single card. It's been like that for a while now.
digitaldurandal
1,828
The temperature you see only matters in relation to the temperature that chip remains at during load. It does not equate at all to the temperature released. Think about physics and entropy. *All* energy eventually becomes heat and whether you use water cooling or air cooling an equilibrium of temperature will begin to occur in the surroundings.
Therefor the most relevant number to heat release is power usage.
A good cooler may move the heat off of the chip and into water that is then cooled off with air. However, please notice the last piece in the puzzle.
Abwx
11,873
4,857
Well, Nerp pointed the temp albeit it can be compensated with a custom cooling, but that wont solve the TDP issue..
I could imagine that someone who need 16+ Tflops of single precision capability would be interested.
Seems to me, if i can borrow 3DVagabond s term, that computing was also a winning point not so long ago, it s crazy how things can change in so few time...;)
topmounter
194
18
For mining I get it, but for gaming it still requires CF support to take advantage of both GPUs, correct?
