First AM2 CPU Block
Are you sure a Storm Rev.2 won't fit on it?
Remove the standard bracket and just use the hole in the mobo, and none of the holes on the Storm match?
I don't know, don't own any CPU water blocks. But this is the first block that I've seen that expressly says its AM2 compatible. Others might work, some might need a slight mod. I'm hardly an expert on water cooling.
