Firmware update Issue?
fanunez
Name Brand: Belkin
Model: F9K1102 V2
n600 DB Wireless N+ Router
Okay so the router was working absolutely fine, but my router's main page said it needed a firmware update so I did so and right after that it just stopped working completely. The modem seems to be working fine, I tried manually updating the router through a laptop and it keeps giving me this weird binary error page Binary is error, please choose correct one. (may be pid is not correct) just like this...
So I tried resetting it and also resetting the modem and all the basic steps here in the forums, but nothing seems to work and it's starting to get a bit annoying and I need help from some one wiser.
I also tried resetting them by pushing on the red buttons and unplugging them, but the router gives different errors once in a while, it proclaims that the connection between the modem isn't being established or some other BS, also it was working through Ethernet cables, but I don't see the router's WIFI name on the wifi list on any portable device.
The router also keeps flashing Blue then Orange, which I believe means there's something wrong because it usually is left on blue not sure.
silicon
886
Name Brand: Belkin
Model: F9K1102 V2
do you have the correct firmware for the router? Can you access the router thru the browser? When you reset you may need to press the reset for quite a few seconds to clear it. What is PID?
shadowman724
43
www.keyboardbanger.com
Can you get to the "At the Utilities --> Firmware Update" page? If yes, do you get the "Firmware update in progress" message? Can you share some screenshots?
