HI All
I am trying to connect my firewire port on the front of my case to the header on the
Intel 865perll motherboard. The firewire connection on the motherboard has 10 connections. The wire to my Antec case only has 6 wires.
The connections on the board are labled
1 tpa1+ 2 tpa1-
3 ground 4 ground
5 tpa 2+ 6 tpa2-
7 +12v 8 +12v
9 no pin 10 ground
The lead wire from the Antec case has 6 wires labeled
1 tpa + 2 tpa -
3 tpb + 4 tpb -
5 vp 6 vg
So there is 3 connection missing. I probably can disregard two grounds. But then which 12v connection should I use and which ground should i use?
thanks in advance
1 tpa1+ 2 tpa1-
3 ground 4 ground
5 tpa 2+ 6 tpa2-
7 +12v 8 +12v
9 no pin 10 ground
1 tpa + 2 tpa -
3 tpb + 4 tpb -
5 vp 6 vg
thanks in advance
