Firefox Problems -- Slows to a Crawl after about 1 hour of usage?
Oct 30, 2004
11,442
32
This past week, my Firefox has begun to slow to a crawl after about 1 hour of usage. When this happens, I cannot get the bookmarks to open up (or at least pulling up that menu is very slow) and I have to go to Task Manager to shut it down. I don't know if it's an update to Firefox itself that is causing this or if it was an update to an extension.
blackangst1
22,902
2,359
Werent there memory leak issues with FF? Im not sure I dont use it but I seem to remember that. Is it current?
0roo0roo
64,795
84
uninstall, remove all directories linked to it, reinstall.
If it "leaked" that bad no one would use it
pkp413
59
You're not alone, I have it on three PCs and it got so bad on all three that I have switched to Chrome for good even though Chrome is still Beta and is not a full blown app yet (very poor print support). But its good enough for casual browsing and 10x faster than FF with almost no crashes (FF crashed after 2-3 hours of use for me, but I had it retain 999 days of history data).
If you want to stick with FF, try to minimize the amount of history data stored in form of history/cookies/passwords and see if that improves performance. FF keeps all that data in a database. It begins to hog the system once that DB get big.
Also, try the following if you believe you have a large history DB (this will defragment it and improve its performance)
- Open the Error Console: Tools menu/Error Console
- In the Code text box paste this (it's a single line): Components.classes["@mozilla.org/browser/nav-history-service;1"].getService(Components.interfaces.nsPIPlacesDatabase).DBConnection.executeSimpleSQL("VACUUM");
-Press Evaluate. All the UI will freeze for a few seconds while databases are VACUUMed
bobross419
1,981
I've noticed my Firefox install on my HTPC is having some serious leakage when watching Hulu. Before the most recent update, I was seeing Firefox climb from 100MB to about 400MB, this would be about the max even left on pause overnight. The other day (post update), after pausing overnight the mem usage for Firefox was 1GB+ - We had freshly restarted Firefox, loaded homepage (Google.com), then used a bookmark to get to Hulu's Quantum Leap Page. We were about half way through 1 episode of Quantum Leap (48 minutes @ 480p). This is way more usage than I'm used to seeing in Firefox.
Chiefcrowe
5,056
199
Yes, your profile may be damaged somehow. If you've eliminated any addons as the problem, then I would uninstall, delete all profile related folders and install again.
Kev
16,367
4
I had serious performance issues with FF recently. Uninstalling greasemonkey fixed my problems
Oct 30, 2004
11,442
32
Here's a list of my Add-Ons. (I intend to reinstall the ones in Red if I reinstall Firefox.) Wait, that's a list of Extensions, not all of the Add-Ons. For now, I'm disabling the Java plugin and all Java stuff.
Add Bookmark Here 0.5.8
AVG Safe Search
AVG Security Toolbar
Bookmarks Scrollbar 1.1.0
CatchIT! 1.0
ChatZilla 0.9l86
Customize Your Web 0.4.2.2
DownloadHelper 4.7.2
DownThemAll! 1.1.9
Dragdropupload 1.9.36
Duplicate Tab 1.0.2
Enhanced Bookmark Search 0.1.4.04.1
FireFTP 1.0.7
Flagfox 4.03
gDocsBar 0.5.7
Greasefire 1.0.4
Greasemonkey 0.8.20100211.5
Java Console 6.0.12
Java Console 6.0.03
Java Console 6.0.07
Java Console 6.0.05
Java Console 6.0.14
Java Console 6.0.15
Java Console 6.0.16
Java Console 6.0.17
Java Console 6.0.18
Java Console 6.0.01
Java Console 6.0.02
Java Console 6.0.13
Java Quick Starter 1.0
Map This 0.3.1
Microsoft .NET Framework Assistant 1.1
Platypus 0.81
Print Preview Toolbar Button 0.1
Session Manager 0.6.7.4
Tab Mix Plus 0.3.8.2
Tabbrowser Preferences 1.3.1.1
Toolbar Buttons 0.6.0.8
Wikipedia Lookup Add-on 0.3.8
lxskllr
60,202
10,662
DownThemAll! 1.1.9
FireFTP 1.0.7
Flagfox 4.03
Java Console 6.0.12
Java Console 6.0.14
Java Console 6.0.15
Java Console 6.0.16
Java Console 6.0.17
Java Console 6.0.18
Java Console 6.0.13
I have these installed, and no issues.
Oct 30, 2004
11,442
32
I installed Google Chrome and wasn't particularly impressed with it other than the speed.
So I decided to do a complete reinstall of Firefox. I saved a couple bookmark backups and wiped everything out. I don't know if the problem is gone since I haven't used it much, but so far the new install is radically faster than my old Firefox install.
However, the reinstall didn't kill or remove various plugins, which Firefox seemed to automatically detect.
11,442
32
Update. It's much faster after the reinstall, but it's still doing the same shit.
If it isn't a mucked up plugin, then the only explanation I can think of is that I switched from a wired mouse to a new wireless mouse recently. It seems to have started after that. Why a mouse would affect Firefox, I have no idea. I didn't install any special drivers for the mouse.
M0RPH
3,302
Start firefox with -P switch and create new profile. See if it still does it with a clean profile.
Oct 30, 2004
11,442
32
I guess I could try that. When I did the reinstall, I deleted everything in the "Mozilla Firefox" folder though I never thought to check Application Data folders.
13Gigatons
7,461
500
Delete all the Java Consoles:
Java Console 6.0.12
Java Console 6.0.03
Java Console 6.0.07
Java Console 6.0.05
Java Console 6.0.14
Java Console 6.0.15
Java Console 6.0.16
Java Console 6.0.17
Java Console 6.0.18
Java Console 6.0.01
Java Console 6.0.02
Java Console 6.0.13
They can be found here:
D:\Program Files (x86)\Mozilla Firefox\extensions
Like others said try a new profile as well.
jstnmarsh
I recommend regularly clearing off the cache and the other related temporary files to have a smooth running working with FF. You also require to have a regular update to FF, this would help eradicate any errors if there's any. Also deleting all the extended Java files also helps sometimes. If you follow it regularly then I don't think there will be any problems with FF.
pcslookout
11,959
157
My firefox never goes above 850 MB, this is with keeping firefox open 24/7 never closing it. Took a while to fix but finally did. I have 8 add ons and 1 plug in installed.
Oct 30, 2004
11,442
32
Java Console 6.0.12
Java Console 6.0.03
Java Console 6.0.07
Java Console 6.0.05
Java Console 6.0.14
Java Console 6.0.15
Java Console 6.0.16
Java Console 6.0.17
Java Console 6.0.18
Java Console 6.0.01
Java Console 6.0.02
Java Console 6.0.13
My extensions folder seems to be empty. It has the gibberish name folder and that only has three non-Java files in it. And yes, I have them set so that I can see hidden files. I wonder where the extensions are.
Oct 30, 2004
11,442
32
It's possible that it may be the AVG Safe Search and AVG Security Toolbar causing the problem. At least they seem like good culprits. I've disabled them. Hopefully that solves the problem.
