- Feb 11, 2005
- 4,263
- 0
- 0
This is most likely really obvious, but I can't get it to let me install a plugin from Google.
1.5 final
1.5 final
Originally posted by: Jolt2
This is one of the problems I had too. Here is what to check:
1. Type [ about:config ] into your Firefox address bar.
2. Navigate to the "xpinstall.enabled" entry. It is toward the bottom of the page.
3. Right-click the "Value" section and select "Toggle" to change value to "true".
That should take care of the plug-in install problem for most. The other problem I had was playing media files with Firefox 1.5. That problem had to do with the Adblock plug-in. If you have Adblock, open "Preferences" in Adblock. Now click "Adblock Options" and un-check the box for "Obj-Tabs" from that page.
