Firefox 1.5 + Adblock + Flash = problems...
Cheetah8799
4,508
For all you Firefox 1.5 upgraders like myself, if you use the Adblock extension, you probably noticed that Flash stuff doesn't show up anymore. If you're like me, you tried upgrading Flash. Well, that doesn't work. I happened to find on Fark that someone posted that Adblock is causing the problems. If you upgrade to the latest greatest version, you'll be OK.
Now, the Extension manager is supposed to do this, and mine supposedly did, but in reality it did not. So, go to this URL and click the Install Now option. Then close Firefox and re-open, you should be all set.
https://addons.mozilla.org/extensions/moreinfo.php?id=10&application=firefox
To test it, go to macromedia.com and see if the Flash stuff there works.
microAmp
5,988
110
Check my signature, AdBlock Plus works with Flash 8 but not sure about 1.5 but works with my 1.0.7.
