fire wire pin out
Tommunist
1,544
my case has a firewire port with the follow leads at the end:
GND
GND
VP
VG
TPB+
TPB-
TPA+
TPA-
and the motherboard has the following pins:
GND
+12V +12V
TPB- TPB+
GND GND
TPA- TPA+
So it's obvious that I'm one lead short of populating all of those pins.
The TPBs and TPAs obviously match up. And I should be putting the VP to one of the 12V+ and 2 of my GNDs to the 2 of the 3 GNDs but which way is the right way?
My case manual says that:
VP = is the power
VG = ground
So if VG is ground this means I'm short one 12V+ lead?
How do I hook this up?
Many thanks and hopefully my description was clear...
LED
6,127
Hook em up as stated and try the VP on either on of the +12V. Maybe the Case has 1 firewire Port where as the Mobo supports 2?
Tommunist
1,544
well i know it's one port b/c there is a backpanel firewire port that i'm opting not to use that has the leads all in one harness and this harness takes up all of these pins.
