- Jun 28, 2004
- 1,791
- 201
- 106
Just wondering has anyone compared the Amazon Fire tv picture quality vs an Intel Nuc picture quality with both blu ray and dvd content? Are they close or is one better than the other? (local media mkv files)
Kodi on a NUC will be better due to HD audio support, true 24p support, and the fact that a FireTV cannot play VC1 files worth a damn (many Blu Rays use the VC1 codec).
BUT
Does that matter to 90% of people? Hell no. Most don't have expensive speakers that can utilize HD audio, most can't see 3:2 judder, and most people don't rip their own Blu Rays to run into VC1 files (99% of content in the "scene" is x264). So I would argue that for most people the FireTV might be a better option, because then you easily get Kodi, Hulu, Amazon and Netflix on the same box.
Me? I am a purist. Every TV has a Chromebox running Kodi. Any ARM box outside of the Pi2 is unacceptable for me for Kodi use.
But I cannot recommend that for everyone.
Thanks. I don't use a receiver but a good amount of my blu rays rips are probably VC1 files. Looks like I will use a Skylake NUC when they come out.
Probably? Make sure....
I'd bet they're probably not VC1 and most likely x264.
But if they are, I'm surprised you'd go through the trouble to then not have an actual setup to watch the bluray on.... Pointless to me, but I'm in Poofy's camp of a high end audio setup. However, I can not tell the difference between a high bit rate encode and a blurray rip after much comparison. So I encode to high bitrate and I'm happy as long as it's high bitrate, and HD Audio. HD Audio is the most important to me, I love speakers/sound. I need a house so I can actually use my things lol. Soon!
The Pi2 can do VC-1 for an extra dollar or two. Its also a pretty cheap investment to try it out. You can get one from aliexpress with a crappy case for about $40. Not perfect, but very usable.
Would there be much of a difference between a NUC and a Pi2?
-The NUC will run the interface on heavy skins smoother.
-A Skylake NUC will be able to play HEVC/10bit content that a Pi 2 can't (mostly matters for 4K and scene Anime)
-HD audio
Edit: Forgot that an x86 box can use some plugins that arm boxes can't use. This is changing fast though.
Otherwise not really. A Pi 2 is a GREAT 1080p Kodi device.
Sorry I meant to ask if there would be much of a difference in picture quality. Was a long day yesterday.
They just announced the release date for the new Fire TV, ICYMI
