FIOS router loses wireless
ThePiston
861
I've got the Actiontec m1424wr Verizon FIOS router. It's got a built in wireless and it works fine - usually. Every now and then the wireless will turn off. I don't mean the light turns off or the checkbox becomes unchecked - it just stops working. Everything in the settings is fine, the radio is enabled, SSID enabled, wireless light is on - all fine, but no signal. I've got it to work by resetting the router, but this time that's not working. Anyone heard about this? Nothing has changed, just no signal.
