Originally posted by: NickOlsen8390
From what i have heard if you have TV from them you have to do coax, because without the modem on coax the ondemand stuff for the tv doesn't work.
Originally posted by: Tbirdkid
i dont understand why you cant bridge on the actiontec. i just plugged it into a port on the router (not using wireless for bridging) and set it up in the software of the second router to bridge to the other router. I only use it for my xbox360. I would guess its the same way if you use it for wireless.
wirelessly bridging, or wired? it matters.
Originally posted by: Gibson486
Anyone here have fios internet over ethernet? If so, does TV still connect to the coax at the STB? I am trying to figure outif it is worth it to push verizon to switch me to ethernet from the stb for internet.
Correct, all of the STBs will still need to be connected to the ActionTec router via coax, but you can hook up your own router as the "edge device" and have your ActionTec act as a bridging device and hang off of that.
http://www.dslreports.com/faq/15993
