Finished overclocking my DFINF3 250 & Sempron 1800
mattburk
Ok, the final numbers are in.
cpu 2496.06
HTT 312.01
Memory 249.61
Not bad for a 1.6 cpu
Parts:
MB DFI UT NF3 250gb
cpu amd sempron 2800 1.6
Ram OCZ plat 3200rev 2
psu Mad dog 500watt
os Windows xp pro with all updates
CPU Fan Zalman 7000
Video card (weak link) ATI Radeon 9500 pro.
I am doing the benches now. I hope all holds together well, and remains stable.
Only complaints:
1. Manual is next to useless. They should really walk through the bios with you!!
2. Nforce 3 chipset will not take my tv tuner card, love that card.
3. Nforce ide drivers will not work with my maxtor sata drives. Will not even boot up with a new unformatted drive in any of the sata slots.
4. Had a hard time getting the usb ports to work at usb 2 levels, had to reinstall the usb 2 drivers a few times off of the cd, this is even after doing all the windows updates.
Overall, it is a great overclock, and if all remains stable long term I will be happy. If this turns into unstable city, then I will go for a different board.
Any body get a dfi nf3/4 to work with a maxtor drive?
I thought I had it fixed when I uninstalled the dfi ide drivers. That worked for about two days. Now my hard drive does not show up and I am getting unstable boots.
Any help would be welcomed.
Thank You
Matthew
