Finished my first attempt at case mod
Nice job, great color.
With the Thermaltake Dragon Orb:
Idle temp was 43c for cpu & 27c for case
Running Seti 24hrs temp rose to 47.5c for cpu & 29c for case.
With the CoolMaster HHC-001:
Idle temp is 36c for cpu & 26c for case
Running Seti 24rs temp rose to 39.5c for cpu & 29c for case.
So it is working good.
But since I moved everything into the new case my temp have gone down 5 degrees C.
hey, your sister's HOT!
nicely done, if you got some split looms or such for the power cables, it would be even cleaner. good job!
