Finally woke up from years of shuttle SFF mistakes - Need your help on new System!
dlevens
14
Brief Summary
I could really use some extra help on this new system build. I have been building systems for myself, friends and family for over 15 years now and to be very honest I think I have been completely happy with only one or two of these. I think my last rock solid box was a dual boot NT4 Workstation and win 95 for gaming box that just worked like a horse.
For some dumb reason I got on this Shuttle SFF kick a few years ago and man what a mistake that was. I must have built over 15 of these little boxes and most of my family is now on them, and not one of them is without issues. I finally migrated off my SN95G5 and SN25P so I can ditch these piles of junk on ebay.
So long story short I am desperate to build a rock solid box and as I cannot seem to pull this off myself I could really use some extra feedback to make sure I don't make any major mistakes. I do not have much history around here as I wasted all those years posting issues with shuttle sff cubes over at sudhian.
What I want
The most important thing to me is stability, rock solid with no issues.
Second is speed
Third is features like firewire, usb 2.0, SATA and great onboard sound
Fourth is quiet, if all the above can come in passive heat pipe then even better.
I do not plan to overclock, and all the times I thought I would overclock, I usually tried it and then backed off to stock speed to keep things stable.
I also do not use RAID. I run 3 systems at home and a nice Linksys NAS so backups happen nightly hard drive to hard drive.
How I use my main rigs. I game a few times a week, always the latest turn based and strategy with a FPS once in a while. Currently AOE 3 and CIV 4, always having skype on for voice during gaming. I use my system to process my RAW digital photos, and Mini DV cam footage of my kids, family etc, so use a lot of Adobe CS2, and Avid etc. Everything else is typical stuff any computer can handle.
What I have already
ATI X800XL PCI-e Video card
Western Digital 400GB WD4000KD SATA ( just bought this and thinking of returning for the WD4000YR )
Western Digital 250GB WD250KS SATA
CORSAIR TWINX1024-3200LL 400MHZ 2X512MB (MATCHED PAIR) 2-3-2-6 DDR
PIONEER DVR-108BK DVD DUAL DOUBLE LAYER REWRITABLE DRIVE
AMD ATHLON 64 3700+ W/1MB CACHE 90NM (SAN DIEGO) 64-BIT SOCKET 939
What I am planning so far
Case: Antec P150
Video: keeping ATI X800XL PCI-e
Drive: Keeping the two WD above and setting up as
400GB (50gb C drive - XP, page file and all applications) (rest on D for storage)
250GB (50gb E drive - Games and second page file) (rest on F for storage)
From what I have gathered over the years two hard drives with a page file on both, a small partition for OS, and seprating the game install on seperate drive than OS gets the most performance. Keeping the applications games and page file to the first 50gb of a large drive also performs better.
Memory: Ditching the Corsair on ebay and getting OCZ's VX line or Mushkins Redline but not sure which and what specific chips yet. All I know is I want 2gb of ram and the best fit for the motherboard I choose.
Motherboard: I have no idea yet, but do know I want to go AMD X2 and am looking at Asus and DFI. I liked the idea of one of the latest asus boards with heat pipe for cooling but apparantly this board has issues and the onboard sound is no good? I liked the DFI Ultra D but not sure this is the perfect fit just yet. I could really use some help here.
CPU: Most likely AMD X2 4400+ since it is the cheapest one that has 1mb cache. If you think the 1mb cache is not needed then I might consider saving money and getting the 3800+ with 512 cache.
Sound: If I can get away with onboard sound I will, but the last thing I want is the sound eating up too much cpu, and definately do not want sound crackling, hissing, popping as I like my skype to be nice and clear while gaming. NOTE: This has been the biggest issue with those damn shuttle sff crap boxes. Always issues with the sound. At the moment I have 3 sets of speakers sitting in the closet, even a nice set of klipsch promedia 2.1. The reason they are in the closet is I hate cable clutter and rarely need a big sub and perfect sound as I have a nice home theather for that stuff. I currently game on some cheap internal mono speaker and find it is all I need in most cases. Eventually I might get a really tiny set of 2.0 speakers but only if they do not come with 40 cables to make them work. Built in speakers to my flat panel would be perfect but I have a Samsung 192T which does not have built in speakers and I probably wont replace this just yet.
Network: Ideally want a solid performer here, as I had a ton of issues on my last shuttle box which had the nforce4 ultra chipset which I believe was a marvel card. Most likely it was shuttles fault on this, but want to make sure which ever motherboard is picked that its network is rock solid. I run only 10/100 still at home as I have not upgraded all my linksys routers yet to 1000.
So now you have the whole story! Any pointers, advice, critiques would be greatly appreciated.
Dennis
tiap
572
If you want stable I suggest a Tyan board to your liking and specs. Never had an issue with one ever and have built hundreds. Tyan is known for usually using the best chipsets. Next choice would be Supermicro. Both cost a few bucks more, but if your not in grade school trying to save a dime, then they are well worth it. It sounds from your post you would appreciate something stable. Asus is not the same as it was 10 years ago.
If you can handle the size, an Antec p180 has great cooling capabilities, although I personally use an Enlight 8950.
As far as sound, I prefer to just digital passthru and use an amp of some kind, either stereo or up to 7.1 with home speakers. Sounds better than computer sound systems. Or you can just run 1 cable to the home theater you have.
I'm satisfied with Linksys as well. My home network never went down in hurricane Rita and ran from a generator.
dlevens
14
tiap, thanks for the suggestions. Never even thought to check out Tyan, will definately look for some reviews on a few Tyans to compare. I have some catching up to do on motherboards, all of the cubes I went through these past few years come with motherboard installed whether you wanted it or not. From what I have read around the boards so far it seems DFI rises to the top for not cutting corners on parts and building solid products, but this is the first I heard that Tyan puts out quality stuff.
Dennis
Arcanedeath
2,822
Tyan / Supermicro make mostly server / workstation boards and both are good makers altho each has had a few bad apples (the Tyan S1854 Trinity 400 comes to mind :) had tons fail just out of warrenty) but if your in the market for a good stable performing board w/ passive cooling for the chipset I'd suggest Asuses new A8n32-SLI Deluxe w/ its 8 phase power circut its prolly the most feature filled silent cool runing motherboard outthere atm. see the review.
teddyv
974
Think about Epox as well - best reputation for rock-solid stability I could find after a month of really researching it. I just bought one (9NPA+Ultra) for my first build and after a couple weeks it hasn't so much as hiccoughed yet.
dlevens
14
arcanedeath,
I think you found it. This is my second look at the A8N32-SLI DELUXE and I am really impressed. Going to find some more reviews on this board just to be sure though. I also bumped into this ALife Gaming Edition and wow, very impressive.
Assuming I go with this board, what is perfect memory for it?
Dennis
dlevens
14
OK SOLD on the Asus A8N32-SLI Deluxe. I am definately getting this board.
According to the Asus website:
The new XMS-3500LL PRO is the industry's first high-density memory that delivers blazing performance at CL2-1T low latency. Available in a matched pair of 1GB modules, it is shipped with SPD programmed at 2-3-2 -6-1T for the AMD platform. The A8N32-SLI Deluxe and the memory are optimized for each other to reach maximum performance, and are validated for stability and compatibility.
Is this just Sales Pictch mumbo jumbo or is Corsair the way to go on this board? I have been a corsair fan for many years (see first post on memory I have now) but to be honest I am losing faith in them. I have not been happy with the recent expensive memory I bought from Corsair. Should I go OCZ's VX line or Mushkins Redline for this board? Do either of these run at 2-3-2-6-1T ?
Dennis
