Originally posted by: VirtualLarry
Originally posted by: hennessy1
I changed my purchase to retail in order to upgrade different machines when the time is right. So I have purchased Vista Ultimate Retail. Also I have a total of 8gb of ram installed currently. I heard stories where I need to remove most of this to install vista then reinstall it. Is this true?
Due to a bug in the installer, MS recommends to only have 2GB of RAM installed when you perform the Vista OS install, then install the updates and fixes (for the RAM problem, among others), and then re-install the remainder of your RAM.
Only problem is, I don't recall if that issue affects only the 32-bit version of Vista, or all (including 64-bit) versions of Vista. Perhaps someone else will chime in.
I personally wish that BIOS writers would add a "limit physical RAM size" option in the BIOS, that way it could be used to get around this vista installer bug without removing your RAM, and it would allow multi-boot with Win98se, because it freaks out with more than 512MB of RAM installed.
