Okay so im planning my first loop out in true finally, and i have some questions. First off should be fairly straightforward. Pending the addition of a full card block for a 5870x2 and possibly a full board block as well, depending on the board im using at the time, these are the parts i have thus far selected. if you have any recommendations for things i could improve upon, by all means. budget is whatever will give me the best bang for the buck, but spending extra money just because you prefer one brand over another isnt worth it to me imo. if for instance, you have a favorite 360x120mm rad, but it costs twice as much as 2 that i picked and doesnt net the same increase in cooling performance, i will probably pick 2 of mine instead.
i used frozencpu as a worst case scenario for pricing, and i plan to use 1/2" ID barb fittings + zip ties to hold everything in place. anyone see any issues with the parts i have picked? i dont believe i mixed any metals, but i dont remember 100% if it was okay to mix brass and copper (the swiftech rad is brass tubing).
i plan on running this loop inside my HAF932 case, with the radiator mounted to the top of the case. based on the spacing available has anyone had any issues mounting this radiator in the top of the HAF? i was really set on this radiator because if desired, i could stack 2 up there no problem.
what does everyone think of the primoflex tubing? i picked it purely as a placeholder until i could get everything finalized for pricing, but i want something which wont cloud up and look like shit over time using distilled + silver kill coils. as for fans, im big on the quiet as much as i am the extreme cooling, and i was planning to use 3 low speed yates (petra's red LED yates, to go with my HAF932 theme).
i know my res doesnt properly support mounting the fillport with tubing sealed to the top, but i picked it up since it will be easier to fill since the HAF932 has a fillport mounting directly over the 5.25 bays, and the are around it is waterproof so i have some spill protection when filling from there. i can just have the fillport there with some tubing attached, and have it there not connected when i dont need it.
the whole system has a red and blue theme to it with blue/UV yates, the red HAF932 fans, and blue gigabyte board and G.Skill ram, so i figured i would keep with the theme with red tubing and a blue res.
i plan on using 1/2" ID barb fittings on everything, since i have heard lots of people talk about issues with compression fittings, besides costing 3x as much as barbs. is there a particular set of barb fittings that works better than others? im not sure where im buying everything from yet, but i know im ordering at least some stuff from petra's since that is the only place i have found that sells LED yates in anything besides blue, but i also need to order some 140mm LED yates for a friend, and for my RC-690, and while petra's doesnt have those, performance-PCs, jabtech, and frozenCPU all have them, so i dont mind ordering from multiple stores
also, how much extra effect would it have on my loop if i were to mount a 140x140mm rad on the back outtake of my case, and a 120x120mm rad on the bottom of my case as well, as far as temps are concerned? i was planning to mount the pump near the bottom of the case where i can find room for it, and go pump>top rad>cpu block>gpu block(s)>full board block>res>pump, and to my understanding adding extra radiators at certain points in the loop doesnt make a big difference vs having them all together at the same point in a loop, but given i have the space to mount them, would it be worth it in over all water temperature, or would the money be better spent elsewhere in the loop to decrease over all temps?
also is there anything i should change with the order i have my loop in? the bay res will be somewhat at mid level in the case, and i figured i would want the pump at the start of the loop as far as where i want the pressure to be, but other than that this is all new to me to be completely honest.
parts i have picked so far:
http://www.frozencpu.com/produ...k_MCR320-QP-Stack.html
http://www.frozencpu.com/produ...rsion_Kit_317_GPH.html
http://www.frozencpu.com/produ...LGA1366_Included_.html
http://www.frozencpu.com/produ...en_Fillport_-_Red.html
http://www.frozencpu.com/produ...servoir_-_UV_Blue.html
http://www.frozencpu.com/produ..._18_Wall_-_UV_Red.html
depending on the launch schedule of the 5870x2 and then full card blocks for it later, i dont mind piecing together the loop in stages, and i have been considering adding a 5870 in at a later date as well with a full card block. with all this, would a single 655 pump be enough? i have heard it is a pretty strong pump, and that it would go well with my EK block. lastly, does anyone know a place i can find full board GA-EP45-UD3P blocks? if there is a place that has these then it would be a lot easier for me to set up than picking separate CPU, NB, and Mosfet coolers as i go along, unless the mosfet and NB coolers are known for being easy to swap from board to board as designs change without much trouble (specifically using the same mountings on one board as another).
