finally junking my old laser printer - need suggestions!
GunsMadeAmericaFree
1,393
379
My trusty ~8 year old $50 Samsung ML-1740 Laser printer is finally having some printing issues - vertical faint lines, and it sometimes grabs 2 or 3 pages at once. I've ordered a new toner cartridge for about $17, so we'll see if that takes care of the light printing & vertical light lines issue for the short term. Even if it does, I took a good look at the rubber rollers and such, and the rubber has become a bit cracked with age. I've been very happy with the laser printer, especially compared to my old dot matrix and a couple of inkjets that I tried. However, I think it may finally be time to entertain getting a new one. (especially since my wife said "We need to get a new one!" last week!)
Does anybody make laser printers with inexpensive toner - especially without all of the chipped things that try to make you buy the expensive, name brand toner cartridges? That has been the main issue keeping me from "upgrading" to a new printer. I've heard through the grapevine that most everything has chipped "copy protection" that tries to force you to buy name brand toner cartridges for ~$80, instead of the remanufactured ones for ~$25 or less like I'm used to. I absolutely HATE that - it's like having someone follow you around and keep you from buying things used at yard sales, and forcing you to always buy new at retail instead.
I've even seen some color laser printers for sale under $120, but I'm turned off by the very high cost of replacing the color toner. ($180 on some models)
Have any of you bought a laser printer in the past year or so that you're really happy with? I know the topic isn't exactly the most exciting or cutting edge, but I'd like to hear from some "happy campers" who have been impressed with the price and quality of their printer. Thanks!
MontyAC
4,112
Check out the Brothers 2270dw. Great wifi laser b/w printer. Get it when it goes on sale.
C1
2,404
117
Interesting as I have the same printer (ie, the Samsung)
A new cartridge should cure the vertical lines issue. Clean the rubber of the page feed roller arm with alcohol that is found just above the paper feed drawer. If rubber stuff is cracking then it is time to replace the printer. This model (or its current equivalent) was on sale at Frys Electronics for like $59 (saw it in the newspaper just the other day). I would go with the 1200 dpi version though.
donfm
677
Second on the Brother 2270DW. I own it and its been a reliable workhorse for me and aftermarket toner is readily available and cheap. It features WIFI, ethernet and USB connections, and dual sided printing.
Theoretically by replacing the Samsung toner cartridge it's like getting a new printer since both the toner and drum come in the same cartridge. That should take care of your lines. Wow if you got it for $17 I think you did well.
