Aikouka
So, for the longest time I was using what are essentially 5.1 PC speakers for a TV, just to give a bit of an extra oomph and get some nice surround sound. Well, I decided to upgrade to a real setup. Unfortunately, my full setup was delayed by being unable to pick up my AVR and sub, so I'll have to wait to finish until tomorrow, but to give an idea, here's a crappily taken picture!
http://www.aikouka.com/photo.jpg
( After seeing these, the UPS guy asked me if I was planning on "blowing anyone away" :awe: )
The full system is comprised of:
Denon AVR1610
2x Polk Monitor 70 (front)
2x Polk Monitor 50 (rear)
Polk CS10
Polk DSW Pro 600
Now, to give you one of those "laugh at the noob" moments, when I was stringing the wire, I originally thought that "hey, the insulation keeps these held in better if I clamp the caps onto them!" (Note, I did strip the wire obviously, but still had some insulation going into the hole) Yeah, apparently, you're not supposed to do that and I would've gathered that easily from the instructions had they used something more than a picture. The guide for my center channel specifically said not to insert the insulation into the post hole though. So, crisis averted! I guess it makes sense since I assume the posts will get hot (given they'll have a decent amount of electricity flowing through them). Now, the insulation pretty much stops at the edge of the cap, which should be alright.
Oh and a question... I originally ordered some speaker wire from Monoprice, but apparently I won't get the wire until Monday. My impatience would not stand for this and I went to Home Depot to buy some speaker wire. Is the fact that the speaker wire uses copper on the positive and silver on the negative a bad thing? I believe the Monoprice cables use copper for both connections.
I also made sure to order The Matrix on blu-ray just for the lobby scene 😉.
Denon AVR1610
Polk CS10
Polk DSW Pro 600
