TheAntiChrist
After soooo very long I've finally finished building my new computer. I go to turn on the power and it seems fine, and everything has power. One little problem though....nothing happens after that. nope, no bios, no beeps, NOTHING. I've spent hours double and triple-checking that all connections are good, and that everything is plugged in right and has power. I swapped the memory from my stick of PC3500 DDR to a stick of PC2100 and I'm having the same problem. swapped monitors, same problem. Swapped the video card, nothing. Whats strange is that I hear no beeps at all except when i hold the power button for about 5 seconds to shut it off, i hear one. I really don't think it's an issue of power, because all fans work and and everything powers on when i start the computer. Also interestingly enough I had the same exact problem occur after i was done swapping the memory and put it back into my old computer. My old computer did the exact same thing. I cracked the case and went in to investigate and discovered i installed the memory backwards (I felt too stupid to even call myself any names at that point). I fixed that, and bam my old computer was up and running again. I then checked about 3 different times to make sure the ram in my new computer was installed correctly, and swapped the ram again with a different module, etc. I have absolutely no clue whats going on, I should at the very least get to the bios screen but nothing shows up on the monitor at all from the time i press the power switch. If anyone could help me out in any way I would GREATLY appreciate it! Thanks 🙂
Here are my system Specs btw:
Athlon 64 3200+
Asus K8v SE Deluxe
Antec Sonata Case w/ 415 watt Enermax Whisper Power Supply
512 mb Corsair XMS DDR PC3500
Dual Seagate Barracuda's 7200.7 SATA 160gb (for total of 320gb RAID0)
Ati Radeon 9700 PRO
19' NEC MultiSync FE950 Monitor
Creative Soundblaster Audigy 2
Plextor PX708-A 8x DVD Burner
SONY Black 1.44MB 3.5inch Floppy Disk Drive
Logitech Dual Optical USB Mouse (Ruby Red)
Logitech Internet Navigator Multimedia Keyboard
Athlon 64 3200+
Asus K8v SE Deluxe
Ati Radeon 9700 PRO
