mrjoltcola
- Sep 19, 2011
- 534
- 1
- 0
Actually I like 42 multiplier best, but I'm a nerd.
I'm no pro at OC, and I'm very conservative (I run my business off my PC so can't have junk getting corrupted just for 200-300 mhz). At 4.7Ghz my PC appears to run fine, regular apps act right, but weird things happen that can even emulate software bugs. Visual Studio starts throwing odd compile errors, my Kingston 6Gb/s SATA3 drive starts acting like it doesn't have a partition. All based on overclocking! Bump down to 4.4 and its all sane again. Nothing outright crashing, though. This is what makes me think a _lot_ of folks reporting 4.7+ stable may be cheating.
Anyway, back on topic...
For CPU temp, 80C would seem too high for me (not same as core temps) based on my reading. Note, I didn't say it shouldn't run, I see no problems at that temp, I'm just going by the Intel spec. 72.6C Tcase (measured on the CPU die) is as high as I want to go, though you can be sure, the real number is higher, their "consumer" number is to ensure plenty of safety room. http://ark.intel.com/products/52214/Intel-Core-i7-2600K-Processor-(8M-Cache-3_40-GHz)
Here are my temps today with the H60 cooler. Just testing different frequencies to see what I can run while staying under the official 72.6C. Voltage set on auto.
4.0Ghz / 1.245v Vcore observed
Idle Temp - 33C/91F
Load Temp - 67C/152F - Prime95 large FFT 4 thread - measured at 15 minutes
4.1Ghz / 1.250v Vcore observed
Load Temp - 68C/154F - Prime95 large FFT 4 thread - measured at 15 minutes
4.2Ghz / 1.258v Vcore observed
Load Temp - 69C/156F - Prime95 large FFT 4 thread - measured at 25 minutes
4.3Ghz / forgot to check voltage
Load Temp - 70C/158F - Prime95 large FFT 4 thread - measured at 35 minutes
I didn't go higher today because I ran this in the background while actually doing real work, so didn't want to crash anything.
Idle Temp - 33C/91F
