Final system specs, revise if possible thanks
heres goes 🙂
Creative Labs Desktop Theater 5.1 DTT 2200 5 Satellites With Subwoofer 105.00
AMD Athlon 200 mhz System
Englight En - 7237/3 w/ 300 watt supply (everyone says this is the best)
1.44 fdd
ABIT KT&A RAID - AMD t Bird 1000 mhz (200 mhz)
256 pc 133 , mwaves ram.. i belive its Kingston ram 472.00 Pre-Assembled
Creative Labs Soundblaster LIVE ! Pci 5.1 OEM
LEADTEK WINFAST Geforce2 GTS PRO 32 MB 4xAGP
With Tv Out ( I think this card will serve me as the best for 3 reasons, it will give me great game perfomrance for a good 2 years i think, also dvd playbak will be good i hope, and i can hook it to my tv and watch movies in my room. Does the dvd put onto the tv run well ??) - 175.00
IBM 45.0 GB EIDE ULTRA ATA/100 LP Deskstar 7200 RPM 75 GXP (RETAIL) 177.00
I have a DVD its a 6x samsung form wut i read it will work fine
I also have an iomega cdr
Im gonna install Win 2k i borrowed from a friend, will that be the best os pick ?
grand total w/ shipping all from Mwave (GREAT SITE!!) 1,054.54
now all i need is a moniter
suggestions ?
thanks for all the help
<< and i can hook it to my tv and watch movies in my room. Does the dvd put onto the tv run well >>
Just a warning there....I've never used a LeadTek Geforce2, but it likely uses the Brooktree chip and I've used the Brooktree chip on a Voodoo3-3000 and it was pretty bad...the Video quality is no better than a good VCR.
For best quality from a PC you want to get a Hollywood Plus PCI card, the TV-out quality of that is much much better, a Radeon also does TV-out much better than a GeForce, thought not quit as well as a Hollywood Plus.
However, unless you have quite a good TV then your GeForce will probably be fine for TV-out quality.
I have a 27&quot; TV in my room, it's just a whatever mitsubishi nothing special, and the TV-out quality of the V3 was good enough for it. DVD video quality is really wasted on it 😉
My friend's got a nice 30&quot; I think Sony and I was using that for my test.
AMD Athlon 200 mhz System? Are you sure that's 200?
Over all the system looks quite good. My only warning is if you have a really good expensive TV, that GF2 probably won't be good enough to make full use of it.
