Final case and power supply decision.
BZeto
2,428
Ok, its either this:
Black Enermax
Or this:
Cheiftec Dragon Blue case
I would put an Antec 430 Watt true PS in both of em. The first one would be cheaper to upgrade to the powersupply, and if I bought one with the blue cheiftec it would be more expensive. Also, the enermax comes with a neon light but I hear it doesn't work that good.
I like the Enermax because of the fan possibilities, there is a top exhaust and you can put a 120mm on the front.
Which one do you think would be better for a low temp system?
Anyone with either of the cases please gimme some feedback about them.
thanks
cremator
643
chieftec, since its exactly like the antec case, and it has 2 intake, 1 hd , and 2 exaust fans in the case itself....locking hd case...locking cd rom door cover...and mmm RAIL MOUNTED DRIVES.
