I am about to place an order with Newegg to build a new gaming / media computer and I'm looking for advice in a few areas.
Questions
1. Is there somewhere I could save money by buying a just-as-good alternative for any of the parts I have listed?
2. Is there something that is about to come out just on the horizon that would be worth waiting for?
2. Is there anything dumb I'm doing in regards to this specific combination of parts?
Facts:
~ I will be playing Diablo 3 and other games over the next two years, but primarily I want iTunes to run as fast as possible and Plex media server to run well.
~ Don't need optical drive, OS, or new display. Will be running with 1920x1080 resolution. May upgrade to dual monitor gaming in within six months.
~ Looking for a quiet(ish) decent looking case that is easy to work with and with USB3.0 in front. Not sure if the Fractal Design Define XL is the best solution or not.
~ Planning on using SSD for OS and applications. I think I can get by with 60GB. 2TB drive for data.
~ Won't be overclocking unless the effort really ends up being worth it.
~ Buying in the USA.
Prospective build:
Case: Fractal Design Define XL
Storage: Intel 330 60GB / SAMSUNG EcoGreen F4 HD204UI 2TB
CPU: Intel Core i5-2500K
GPU: SAPPHIRE Radeon HD 6870 1GB
PSU: CORSAIR Enthusiast Series TX750 V2 750W
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 2133
Questions
Facts:
Prospective build:
