LTC8K6
- Mar 10, 2004
- 28,520
- 1,575
- 126
A rumor from over the weekend suggested the 380 is a 285 with more memory and a 256bit bus.
That is just more memory then. No change to the bus width.
No matter if those pricings are made up or not...I actually expect AMD to lowball like this.
The 300 series is not about being the best in terms of performance...it's about staying relevant at any cost until 2016.
That's great for us the user...but let's see what will actually happen..time for AMD to finally spill the beans.
But I would actually bet for AMD to try and beat Nvidia on every front by pricing alone. Still hoping for Fiji XT actually being as fast as a Titan...just so thriving for more and more performance asap is something that stays relevant.
I dont know.
4096cores at 1150MHz, seems way higher than I expected. Usually the clocks for Radeon cards are top 1000MHz, now its 1150MHz? On top of that you got so many cores in one silicon?
Doesnt make much sense.
Then there is that 8GB HBM which also doesnt make any sense regarding all the interviews AMD did and said 4GB is enough and that they have drivers etc making sure the graphic card will work fine with it.
ID for this card is 67C8.
Hawaii 290X is 67aX
295X2 is 67bX.
So I guess a bigger chip than those two makes sense to have that ID.
Not sure, not sure
Fiji apparently has 2 8-pin power connectors, so I wouldn't expect miracles.
8GB Fiji disagrees with you
8GB Fiji is not even officially confirmed yet... Something that officially does not even exist yet can not disagree with me.
Right now ALL the infos are pretty wonky.
So what? Titan X also comes with a 6 + 8 and has huge OC headroom (but needs water to reach it, regardless). HBM sucks a lot less power than GDDR5...especially 12 GB of it. So even if the card needs a legit 2x8...theres a water version and more power goes toward GPU than ram...that would only indicate the possible monstrosity that this thing COULD be.
http://forums.anandtech.com/showpost.php?p=37443775&postcount=17018GB Fiji is not even officially confirmed yet... Something that officially does not even exist yet can not disagree with me.
Fiji vr 2x8gb hbm 1399-1499
Way too big a gap between 399 and 599, and if the 599 part is only 4GB, that's a mistake. It doesn't matter how fast you can crunch data if you run out of memory and have to swap textures on slower system RAM. 4GB will barely make the cut regardless of how fast the card is otherwise.This was also leaked by a distributor on ChipHell:
R9 380 4gb 199
R9 390 8gb 299
R9 390x 8gb 399
Fiji pro 4gb hbm 599
Fiji xt 4gb hbm 749
Fiji xt /xtx 8gb hbm 849
They need a Fiji Pro card at 499 with 6gb in order to be relevant price-wise. 599 is too close to 649 6GB 980Ti.
SO why are the Fiji cards only showing HBM? Wont the R9 3xx cards have HBM built into as well? OR are the R9 3xx just rebrands of R9 2xx cards?
