FIC VG61 Ice-Cube P4 Barebone 99.99 (refurb)
teKillah
241
www.woot.com
Don't let the Ice-Cube's diminutive size fool you - this system really packs a punch. The Ice-Cube features a lightweight alumuminum case with see through plastic side panels and an integrated handle at the top of the case making the Ice Cube an excellent solution for the LAN party gamer. Upgrades are a cinch thanks to the thumbscrews on the plastic side panels.
Thanks to Intel's 845GE chipset, the Ice-Cube supports up to a 3.06GHz Pentium 4 processor and 2 Gigs of DDR RAM. A 4x AGP slot allows you to upgrade to a high end video card while the PCI slot, one 5.25" and two 3.5" drive bays let you max out the rest of the system with a DVD+RW, huge hard drive, Soundblaster audio or whatever your heart desires. All the expansion ports are easily accessable on the front and back including USB 2.0, Firewire, even SPDIF in/out.
Features:
Supports Celeron and P4 up to 3.06Ghz P4 with HT
Two DIMM slots support up to 2 Gigs of DDR
One 5.25" bay, Two 3.5" bays
4x AGP card slot
Integrated graphics, 6 channel audio, 10/100 NIC
4 USB 2.0, 3 Firewire, SPDIF in/out
Refurbished, white boxed
Included: manual, power cable, driver disc, cooling fan
The Full Specs:
CPU:
Supports Intel Socket 478 Pentium 4 processor
Supports Intel Socket 478 Celeron processor
400/533MHz Intel NetBurst micro-architecture bus
Chipset:
Intel 82845GE + ICH4 chipsets
Winbond W83627HF LPC controller
Realtek RTL8100B Ethernet controller
Agere FW323-05 1394a controller
Main Memory:
Two 184-pin DIMM sockets, supports DDR200/266/333 SDRAM up to 2GB
Expansion Slots:
1 PCI slot, 1 AGP 4X slot
VGA:
Integrated Graphics controller in 845GE GMCH
Supports 3D/2D enhancements
Supports AGP 8X bandwidth. , Max. Bandwidth 2.1GB/sec
Supports extend AGP 4X slot.
Audio:
AC-Link with AC?97 2.2 compliant
Software audio with Realtek ALC650E 6-channel AC?97 codec, S/PDIF output supported
USB 2.0:
Integrated USB 2.0 controller in ICH4
Compliant with USB 2.0 specification
Supports USB 2.0 and 1.1 - Max. Bandwidth 480Mbits/s
Ethernet:
Realtek RTL8100B 10/100Base-T Ethernet controller
Full-Duplex supported
WFM 2.0 compliant
1394:
Agere FW323-05 1394a Host controller
Compliant with IEEE 1394 OHC
I/O Interface:
Two enhanced PCI IDE channels which support up to 4 IDE devices with ATA-100 transfers up to 100MB/sec
Build in FDC supports 1.2M/1.44M/2.88M FDD
Front Panel I/O Output Board:
Double desk USB connectors
PS/2 mouse and keyboard connectors
SPDIF-IN optical connector
Center/Bass, Rear-Out, MIC-in
Back Panel I/O Output:
SPDIF-OUT optical connector
2 Type A USB connectors, 1 RJ-45 LAN port
2 1394 vertical connectors
2 fast serial ports, 1 D-type 15-pin VGA connector,1 D-type Com 1 connector
Line-in, MIC-in, Speaker-out
2 PS2 connectors
System BIOS:
Award BIOS with 2MB/4MB EEPROM
ACPI/PnP supported
Form Factor:
Self-defined @ 262 mm (L) × 180 mm (W), 6 Layers
csyberblue
808
I really want one of these, but the 2 things that hinder me from getting it is that
1) you need an intel processor
2) it has only 1 PCI slot
still a good deal for those that want one
dc
9,998
i've bought from them twice so far. the kensington flyfans and the bag of crap. lol.
ballyn
37
Sold out... Click the woot? link for more info about the site... seems like they have some good deals, but you gotta move fast sometimes, apparently.
MaxDepth
8,757
43
woot opens the deals at 12:01 AM each morning during the week. woot! weekend deals are the ones posted for friday.
I should have $29.99 Dell speaker set arriving shortly...
