- Nov 2, 2006
- 53
- 0
- 0
Originally posted by: spidey07
The same rules should be followed with category rated cabling. Fiber is pretty tough but you can't go around yanking on it or bending it sharply. As scottmac pointed out the tools and connectors to terminate it are very expensive.
With 10 gig coming out for category 6 cabling, fiber (NOT fibre) is not really needed in the home. However if I were to rewire my house I'd just use one of the communications bundles that has two RG6, two cat6a and two strands of fiber just in case.
Originally posted by: kevnich2
Well considering that it's 2 CAT6, 2 coax & a fiber, I'd say it's a good price. Wiring communication cables in a house is a good investment, plus with all that cabling, your pretty much future proofed and I would assume it would up the re-sale value of the house as well for far more than you'd pay to have it installed after the walls and everything is already in.
Yes, but if you're putting in new copper it REALLY should be cat6 or cat6a. 10 gig on copper is just around the corner.
Well, I've taken your advice on shoes in the past. I guess I'll take your advice on this too.
Anything else you can help me with? Haha.
Make sure your cabling is properly grounded and bonded. If your fiber has a metal strength member or is gopher rated, make sure that is grounded and bonded as well. When I talk grounding/bonding I'm talking about a common ground with proper bonding for all cabling - coax, fiber, UTP, whatever you have.
Laugh all you want, this is the difference between a true professional installation and one that is not. I have seen 100 million dollar data centers have communication/EMI/noise problems because some amateur thought they didn't need to follow spec.
When it comes to the home the same principles apply. Grounding/bonding properly is so dirt cheap there is NO reason not to do it.
Originally posted by: anothermacuser
It is hard, annoying and pointless to run fiber for distances less than about 400 feet
Nope, it's not.
If you're already pulling, fiber is no harder than UTP. Even if you don't terminate it right away, it's there, and at some point in the future, it might come in handy. Multimode 4pr isn't that expensive, or if you're by buying composite/hybrid cabling bundles it's not that much more.
I work in a networking industry, so it's also nice for me to be able to play with production equipment at home.
I've moved some of my networking connections to fiber to free up one or more RJ45 Jacks in some rooms. I have 2 Cat6 (actually, Anixter Level 7), two RG-6 Quad, and two pr of 62.5/125 to every location in my house, including closets, kitchen, balcony, and garage. In the bedroom I use as a workspace / computer room, I had an additional loc pulled (three locs in that room versus 2 locs in all the other rooms).
So, don't do it if you don't want to, that's fine. Please leave your broad, pointless generalizations at the door in the way in.
