Few radeon questions ..
gorman
8
First off I have the Radeon 32mb ddr
1. Under display settings -> settings -> advanced -> directx .. the fsaa is disabled. The box is grayed out, and will not let me select to enable it. In addition, when trying to run things like the realmyst setup program, the fsaa box is disabled as well.
2. How do you enable HyperZ? I am not sure if I have this turned on or not ..
3. Do the newest Radeon drivers for windows 2000 fix the poor performance problems with previous w2k drivers?
I'm guessing this questions have already been answered, but I couldn't find them, so figured I would ask.
Thanks,
David Gorman
pidge
Banned
Oct 10, 1999
1,519
1)Don't know
2)Its automatically enabled for OpenGL. It is disabled for Direct3D. Don't enable it thought cause it wreaks havic on your D3D games when enabled.
3)No
