dragonbat13
I have a bitfenix recon fan controller on the way. I got a few questions about using a fan controller.
Should I leave the GPU fan as is (GTX 670 FTW), or should I control it with the fan controller?
The controller also has temperature sensors, but I would rather use the readings given from the Motherboard. Is it possible to use those readings on this controller instead of the thermal probes?
Do I need to have PWM fans to have automatic fan control with this controller?
Thanks.
Thanks.
